Dash Repair
Old April 3rd, 2014, 09:42 PM
Boilerz25's Avatar
Dash Repair
Has anyone repaired a cracked dash pad? I have a small crack running from the top down around the driver vent port on my 69 442. I was thinking of using a filler and then spraying the entire dash pad with a satin black sealer.
Sean
Boilerz25 is offline
Old April 3rd, 2014, 10:13 PM
4speed455's Avatar
I can't comment on the crack, but for the satin black I would go with SEM landau black. It's the correct color and it's made to go over plastics vinyls and even carpet. It's about $12 a can at you local auto body supply store.
4speed455 is online now
Old April 4th, 2014, 05:07 PM
Sampson's Avatar
Google Dash Crack Repair. There is some good info on this. I doubt it could be done so that it is not somewhat noticeable but there seem to be some solutions to the problem!
Sampson is offline
Old April 5th, 2014, 11:24 AM
Mike77's Avatar
Easy solution, a bunch$$$$$$ and call Just Dashes. Beautiful work, but you pay.
Mike
Mike77 is offline
Old April 5th, 2014, 11:45 AM
Boilerz25's Avatar
Mike
Mike,
I was looking at their services but have no idea what the cost is. Do you have any estimates? The finished product is great though
Sean
Old April 5th, 2014, 12:07 PM
Sea five's Avatar
I have a 67 they quoted me $1000.00 need less to say I'm looking elsewhere before i drop a G !!!
Sea five is offline
Old April 5th, 2014, 01:02 PM
501Paratrooper's Avatar
I just got a quote from them and it was slightly under 1,000.
So I cleaned my dash up with POR marine clean, Dawn Dishsoap, SEM Soap, SEM Vinyl and Plastic Prep then put several light coats of SEM Classic Coat. Came out great. Give it a try.
501Paratrooper is offline
Old April 5th, 2014, 01:42 PM
I worked in a car dealership for many years in the used car dept. We had repair venders for all different things, one being interior touchup and repair. You might ask the used car mgr at one of your local dealerships who they use to touchup theirs. I assure you they can work miracles for cheap.
oldcutlass is online now
Old April 6th, 2014, 06:34 PM
Rocketowner's Avatar
I agree with Oldcutlass,there's usually someone that repairs vinyl that check by car dealers weekly ,I'm sure there should be some that are reliable in the Houston area. Larry
Rocketowner is offline
Old April 16th, 2014, 02:01 PM
johns59super88's Avatar
I had a few small cracks repaired and the pad cleaned and dyed for $150 by a local vinyl repair guy. Ask at auto upholstery shops if used car dealers can't help.
johns59super88 is offline
442oldslawyer
April 30th, 2010 08:08 AM
wiseguy58
February 10th, 2010 11:08 AM
wjustinmartin
February 5th, 2010 12:39 PM
1969-442
November 17th, 2009 07:38 PM
Aceshigh
July 1st, 2009 12:13 PM
Quick Reply: Dash Repair
