Removing door panels
Old December 24th, 2013, 08:24 AM
W-27's Avatar
I am trying to remove the passenger side door panel and I have removed all levers, screws, fittings but I am stuck as I don't know how the remove the top portion of the door panel and I do not want to damage it in the process. Any special tools needed?
W-27 is offline
Old December 24th, 2013, 09:08 AM
halfmoontrail's Avatar
Pull door panel away from door at bottom, using proper pry tool to pull out plastic pins. As you free it up from the bottom, you'll be able to slide the entire door panel upwards, to get top of door panel out of window track.
Steve
halfmoontrail is offline
Old December 24th, 2013, 10:38 AM
brown7373's Avatar
Put the window down because sometimes it can catch on it and make it more difficult.
brown7373 is offline
Old December 26th, 2013, 12:52 AM
W-27's Avatar
Steve
Steve, I did all of that but it seems hard to pull the top portion off the door and I do not want to damage the door panel in the process. Are they any plastic pins under the top portion of the door panel?
W-27 is offline
Old December 26th, 2013, 05:52 AM
There is probably a plastic pin a few inches down from the window track on each side.
Old December 26th, 2013, 06:03 AM
starfire's Avatar
Year and model of the car you are working on always makes it easier for people to help you with what you are doing.
starfire is offline
davoaz
April 1st, 2015 03:17 AM
eudaman
May 19th, 2013 05:30 PM
ddx77
June 24th, 2010 10:49 PM
chris83
May 25th, 2010 02:58 PM
Colorado Olds
May 7th, 2008 03:56 PM
Quick Reply: Removing door panels
