Split bench in a car with a solid bench?
Rocket "Scientist"
Is it possible to put a split bench seat in my 1977 Delta 88 when it only has a solid bench? I need another seat, and I've been told it isn't possible without welding in studs, is that true?
I'm thinking of doing some work to this car and keeping it, it's pretty light, it's plenty quick, but I miss my split bench seat.
Rocket "Scientist"
I know that this stuff fits, I just don't know if they did not add studs to the floorboard or some other whacky GM nonsense, I mean, it didn't have rear speakers, so, there is no rear speaker wire. Not that it could be used if there was, rears used a common ground, wired in mono. Just using that as a reference to what companies like to leave out.
Basically, I'm just curious if there are actually studs in the floor with which I can mount the seat too. As I said, I know that GM is of the mindset of "If it isn't being used, don't install it, it saves us 1/5th of a cent per ten cars!"
4-ever-olds
November 14th, 2017 05:56 PM
Wildcard
March 25th, 2013 02:03 PM
yeahbuddy
December 16th, 2011 06:23 PM
