1970 Steering Wheel
This is a picture of when I found my Cutlass S in a shed. Bone stock from the original owner. Hope this helps.
Here is another on a F-85 sedan 1972, also no vents on the dash? I understand the non/ac part with no lower ac outlets and the center upper should be a faux or blocked diffuser. But no side diffusers.
Pat
Pat
The standard wheel is usually(only)? found on F85 cars? The no vent dash only came on post cars without AC I believe. Those cars had the kick panels with one pull **** & they had the wing(vent,fart) window in the door, that's why no side vents in dash.
I found one per your specs. You are correct post cars with no AC.
http://columbus.craigslist.org/cto/4007782503.html
Pat
1970 steering wheel
The rim blow wheel was another steering wheel available for the 1970 Cutlass 442 cars. It was option N42, Deluxe steering wheel with instant-horn. Cost was $15.80. At first glance it looks like the Deluxe wheel.
1k442
February 8th, 2012 12:30 PM
1k442
February 2nd, 2012 10:54 AM
HOT-SHOT10
October 13th, 2011 12:22 PM
