Cutting Holes in Carpet
Old August 4th, 2013, 07:37 PM
starfire's Avatar
I'm installing my new carpet and I need to cut holes for the seat bolts and seat belt bolts and dimmer switch. Is there an easier/cleaner way to do it other than cutting an "x" with a sharp hobby knife? I'd like to cut a clean hole, but am not aware of a tool that will do so.
starfire is offline
Old August 4th, 2013, 08:09 PM
I'm sure a chassis punch would do it, but why bother when it's cheaper, quicker, and easier with a razor knife?
MDchanic is offline
Old August 4th, 2013, 08:31 PM
Tom442's Avatar
Soldering Iron!
that was from a previous thread on tips and tricks....didn't come from me but these Olds guys have all the answers!
Tom
Tom442 is offline
Old August 4th, 2013, 08:37 PM
starfire's Avatar
I can't make very good round holes with a razor knife. Especially that small. I know that no one will ever see it once the seats and seatbelts are in, but it would bug me. Stupid, I know.
starfire is offline
Old August 4th, 2013, 08:38 PM
starfire's Avatar
Tom
That's an interesting idea, I'll have to try it out on my old carpet and see how well it works. My luck, I'll set the carpet on fire
starfire is offline
Old August 5th, 2013, 05:20 PM
jag1886's Avatar
I always just use a box knife and cut and X where I want a hole, seem to work perfect. If you have to have a hole I use a pair of scissors and clip the points off the X.
jag1886 is offline
Old August 5th, 2013, 07:00 PM
bccan's Avatar
Arch punches are what you seek. Not sure they are available singly. I use them on carpet because I'm **** about some (many?) things. I slip a 2x4 under the carpet (& pad), sight my spot, adjust slightly for the carpet sitting flat if stud sticking up & strike w/ hammer into the wood.
I like the results w/ this technique.
bccan is offline
Old August 5th, 2013, 08:42 PM
starfire's Avatar
That's what I'm talking about. Production Tool sells them individually. Thanks!
starfire is offline
Old August 5th, 2013, 09:32 PM
W70442's Avatar
If you really want perfectly circlular holes, you can take the soldering iron method a step further and sharpen the end on a 1/2" or 1"(whatever size you need) copper pipe and heat it up with a torch. Common propane torch would work fine. Not sure if a heat gun would get it hot enough but it may be worth a try if you don't have a torch.
Also, _IF_ your old carpet was the original carpet, look closely at how it was cut at the feet for the seats. They didn't just cut holes, round or square. If I recall, they made a T or H shaped cut so that the carpet lays down flat around the feet.
W70442 is offline
Old August 5th, 2013, 09:36 PM
501Paratrooper's Avatar
I used a soldering iron, worked great.
501Paratrooper is offline
Old August 5th, 2013, 10:22 PM
I'm indecisive. Or am I..
Napoleon Solo's Avatar
When I installed the carpet in my Jaguar I used a hole saw with a high speed drill - worked perfectly with a nice round hole. I identified the center with a punch and drilled from the BACK SIDE onto a 2x4 so I didn't turn it into a ball of yarn.
Napoleon Solo is offline
Old August 6th, 2013, 07:03 PM
Lady72nRob71's Avatar
X2. Just use one that will not be used for solder work again.
Lady72nRob71 is offline
Old August 6th, 2013, 07:10 PM
vette442's Avatar
I was told years ago when I did my first carpet install not to cut an actual hole, but just make a straight slit cut with the blade, or an 'H' if necessary to pull the flaps away to the sides of where the seat mounts, etc. would be. Bolts and studs could be worked through the cut. If you mess up and get it in the wrong place, the slit is pretty much invisible in your new carpet. This saved me a couple times!
Terry
vette442 is offline
RAMBOW
January 9th, 2018 01:51 PM
milesmonte
March 23rd, 2015 07:31 AM
442_Mustang
Suspension & Handling
April 14th, 2010 02:21 PM
Wilson05
October 17th, 2009 07:10 PM
knightvd
October 10th, 2007 05:26 PM
Quick Reply: Cutting Holes in Carpet
