need seats
Old July 24th, 2013, 09:15 AM
babygotcutt's Avatar
need seats
just bought a 77 cutlass and need better seats. any suggestions?
babygotcutt is offline
Old July 24th, 2013, 09:25 AM
seats
just bought a 77 cutlass and need new seats. I'm in the Detroit area. any suggestions?
Old July 24th, 2013, 09:37 AM
jaunty75's Avatar
What's wrong the seats in the car now? Are they missing altogether or so damaged that they can't be sat in? Or is it just simply that they're torn up and need to be recovered? If you need to replace them, you're going to have to find another, similar car to take them out of, and that means junkyards. But if all you need is reupholstering, you can easily have that done for far less trouble.
jaunty75 is offline
Old July 24th, 2013, 09:55 AM
Congrats. I merged your two identical posts.
Define "better". More supportive? Better upholstery? What?
Also, what do you have now, bench, conventional buckets, or swivel buckets? Any newer OEM bucket seats can be adapted, but you'll need to fabricate or adapt brackets. Just be sure that the new brackets ultimately attach to the existing hard points in the floor (namely, to the reinforcements under the floor pan) for safety in a crash.
joe_padavano is offline
Old July 24th, 2013, 02:34 PM
nothing extremely wrong. regular bench seats. wanted to maybe change inside to white leather bucket seats with gear in floor. car already primed and may paint dark blue with iridescent.
Old August 4th, 2013, 07:20 PM
starfire's Avatar
Not around here it doesn't. All the junkyards have closed or have crushed all the old cars. If anyone knows of a junkyard in SE Michigan that has Oldsmobiles from the 40's, 50's, 60's or 70's, please speak up, because I sure don't know of any.
BTW, you could buy these:
http://www.ebay.com/itm/1977-buick-s...545195&vxp=mtr
or theses:
http://www.ebay.com/itm/1977-Oldsmob...35a9b8&vxp=mtr
or if you like to swivel:
http://www.ebay.com/itm/1973-1974-19...946e2d&vxp=mtr
These:
http://www.ebay.com/itm/1973-1974-19...4a4125&vxp=mtr
ebay also has bucket seat covers (the held on with elastic strap type) for as low as $25 and new bucket seat and back seat upholstery sets for quite a bit more, and Tamraz has new foams for the bucket seats.
I would also suggest a trip to here: http://www.73-77olds.com/forums/index.php as they may be additional help.
starfire is offline
Old August 4th, 2013, 07:23 PM
jaunty75's Avatar
Yes, it does. You just have to look outside of southeastern Michigan. Like most of the country, you have to look to the southwest and west.
jaunty75 is offline
Old August 4th, 2013, 07:30 PM
starfire's Avatar
I meant within easy reach. The problem with the southwest is that the interiors are usually trash from the heat and sun. But they could be refoamed and reuphosltered.
starfire is offline
Old August 4th, 2013, 07:49 PM
jaunty75's Avatar
What it comes down to is, do you want the part or not? The days where you could go to your local junkyard for parts for your 40 or 50-year-old car are long gone.
You go where you have to, even if it's outside of southeastern Michigan or wherever you live, and what I said at the top of this thread is still true. If the guy wants seats for his '77 Olds, he's going to have to find a junkyard car.
jaunty75 is offline
Old August 4th, 2013, 08:39 PM
starfire's Avatar
Or someone who is parting out a car (where's that "poking with a stick" smilie?).
starfire is offline
<ILikeMuscleCars:D>
September 10th, 2019 06:59 AM
bryndalfly
September 28th, 2016 11:37 AM
highlander
March 8th, 2010 05:29 PM
rock3390
March 7th, 2010 07:04 PM
Oldsfreak69
January 9th, 2009 02:07 PM
Quick Reply: need seats
