ac and heater removal
Old Oct 10, 2012 | 10:14 AM
mdfedewa's Avatar
i have a 72 cutlass and the ac parts and blower motor are missing, is there any reason not to remove the ac/heater vent box parts from under the dash? if i do ac/heat again i will do vintage air. i also want to replace fire wall insolation and carpet and it looks like it needs to come out anyways. thanks mitchell
Old Oct 10, 2012 | 10:19 AM
Lady72nRob71's Avatar
Do you want a defogger/defroster? Many of the retrofit kits cannot do those functions...
IF you just want those and heat and vent, then just get one of those AC delete plates and a blower motor and wheel and resistor.
Old Oct 10, 2012 | 10:25 AM
mdfedewa's Avatar
nothing is even hooked up right now?
Old Dec 2, 2012 | 08:18 PM
nj_cutlass72's Avatar
I was thinking of removing the AC unit completely and make mine a non-AC car, if I remove the AC unit under the hood attached to the firewall, is there hole behind it and if so how do I cover it? aftermarket plate? its a convertible car and I dont care for AC and rather make it look clean under the hood.
Old Dec 2, 2012 | 08:34 PM
Yep, there will be a hole in the firewall and in the cowl.
There is ac AC delete plate available aftermarket that uses your current blower to still allow defog, heat, and vent positions. It is a shallow unit - about 2.5" deep.
Old Dec 2, 2012 | 08:36 PM
do you happen to have a link for this part? or is it jegs/summit item? thanks
Old Dec 2, 2012 | 08:49 PM
Try this at OPG...
http://www.opgi.com/p/cooling/15817/181/CH27810.html
A bit costly but should work easily. Probably needs a hole cut out in the main airflow for the resistor.
5998DownUnder
Jun 9, 2014 09:35 AM
ATrain1
Jun 30, 2012 07:55 AM
jdana24
Jul 13, 2011 11:15 AM
1968Cutlassfallbrook
Oct 30, 2009 09:05 PM
kevinkpk
Jun 8, 2008 02:25 PM
