How do you remove the cruise control bezel?
Old Aug 11, 2012 | 09:09 AM
jon 72 442's Avatar
I am trying to remove the cruise control from my car and I am not sure how the dash bezel is removed. Is it just stuck on their with some sort of adhesive? Can I just pry it off the dash? I just don't want to ruin it.
Old Aug 11, 2012 | 09:48 AM
NOOO!!!
The cruise bezel is attached from behind. There are 2 posts - top left and bottom right that have speed nuts holding that to the dash. You should be able to access that from below the dash. It looks like you have your gages out, so you might be able to get it from up top too. IIRC the nuts are either 1/4" or 9/32".
How did you get the switch out of there without noticing that?
Old Aug 11, 2012 | 10:01 AM
Here's some visual for you. Look at page 112 (section 1-3) Top right picture. http://wildaboutcarsonline.com/membe..._1.3_-_1.5.pdf You may need to rotate the pics clockwise. (right clik mouse and select option to rotate, depending on your OS)
Old Aug 11, 2012 | 10:16 AM
Lady72nRob71's Avatar
The thin face plate is glued on to the bezel. The bezel is secured with two nuts as mentioned. See if this helps ID where the studs go...
https://classicoldsmobile.com/forums...html#post58161
Might hake a deep socket to get ahold of them.
Old Aug 11, 2012 | 01:18 PM
jon 72 442's Avatar
Got it! Thanks for the info guys! I didn't see the 2 small speednuts when I had removed the switch yesterday.
88hurstolds
Jan 2, 2015 06:53 PM
mruders
Feb 4, 2014 08:15 AM
BeenThere
Mar 10, 2013 03:10 AM
olds70supreme
Jan 25, 2013 07:08 PM
KRICHEN922
Jul 1, 2010 09:17 AM
