Jamb windlace
Old Jun 22, 2011 | 05:22 PM
craftsman1956's Avatar
Jamb windlace
Could someone show pics of the jamb windlace? Starts at the step plate and goes up to the top.my new one doesn't look right and will not fit in place.Thanks!
Old Jun 22, 2011 | 07:42 PM
Lady72nRob71's Avatar
Will this help? I know its small...
Old Jun 23, 2011 | 08:06 AM
Run to Rund's Avatar
Try Year 1 and Restoration Specialties
Old Jun 23, 2011 | 08:49 AM
70Post's Avatar
You have a convertible in your picture....stupid question but did you cut out an area on your new windlace so it would clear the convertible-only striker plate in your door jamb?? (don't know if the new ones come precut).
Post some detailed pics of what you mean about not fitting.
Old Jun 23, 2011 | 05:00 PM
jamb
The windlace is off white and the plastic part is bright white,u shaped as to slide over the metal edge,which it can't do because of the wood.Mine is from opgi.Maybe its for a chev as worded on the bag sticker.Olds windlace should lay as in you'r picture,and staple to the wood.The material that lays on top of metal,and under the striker,should be wider and not plastic,right?I hate to order and return until I get the correct lace,so,anyone know where to get the lace pictured on the brown car? Also,where can I get the arm rest base thats like the original ? Had to return a set that had raised areas from the mould,see pic.Thanks!
Old Jun 23, 2011 | 05:06 PM
Originally Posted by Lady72nRob71
Will this help? I know its small...This is the type I need,fits under striker.
Old Jun 23, 2011 | 08:40 PM
Your sewn cloth looking windlace is VERY different than the original plastic one. It does not staple to anything.
I got a set at the Parts place back in 2008 or 2009 that did not have that raised area at the mounting screw.
See them here:
https://classicoldsmobile.com/forums...tml#post167639
Old Jun 23, 2011 | 08:55 PM
Here are some better pics of my original windlace strips...
Old Jun 23, 2011 | 09:18 PM
70Post's Avatar
Craftsman- The factory original windlace like Rob pic'd has metal inside part of it (the part that slips over the QP edge). The metal acts as a stiffener and helps hold the things in place...no need for glue, etc with factory windlaces.
I'd return those and find a decent set of original used ones...as close to the white as you can get. You can then paint/dye them to match if they aren't close enough.
You may not have liked the fit of those armrest bases anyway....the repros I have seen don't want to fit right. Unfortunately you have a white interior and finding white original armrest bases in nice restorable condition is next to impossible. If you can find clean used ones you can also paint/dye them to match your interior.
Nothing like the original stuff for good fit, etc.
Old Jun 30, 2011 | 03:20 AM
fjross's Avatar
I ended up using the ones from Fusick which where snow white and had to cut out for the convertible brass striker plate. Since my interior is pearl, I ended up buying a can of pearl interior paint from Year One and spraying them to match the interior. I believe they are manufactured by REM.
Dave
Old Jun 30, 2011 | 01:37 PM
windlace
I can try the fusick parts,is the plastic as wide as the striker?I want it to be wide,ones from opgi were too narrow,only would need to cut 1/8 inch.
Old Jun 30, 2011 | 09:43 PM
fjross's Avatar
Like Rob has posted in the previous pictures, the windlace will need to be cut around the striker plate. The aftermarket R.E.M. was not as difficult to cut as the original since it doesn't have the metal splines.
Old Jul 1, 2011 | 03:54 PM
I know the plastic needs to be cut,but,I was looking for an aftermarket windlace that has the same width plastic(the part that gets cut for the striker) as the original.The plastic slides onto the quarter panel edge.Original width is 3/4 ",after market windlace i bought, has only a 3/8 to 1/2 inch wide plastic.Could you poast a pic of the fusick windlace on the car showing the striker plate also? This would help me.Thanks for you're help!
Old Jul 1, 2011 | 04:32 PM
I do not recall mine having any metal in them.......
Old Jul 1, 2011 | 10:00 PM
70Post's Avatar
If they're factory then they have metal in them. The metal is inside of the part that slips over the QP edge (actually only the flap that fits behind the QP lip. Don't think there's metal in the flap you cut for convertible striker clearance).
The round welting part is just foam filled for shape.
Old Jul 2, 2011 | 05:20 AM
fjross's Avatar
If you could wait till after the holiday, I could send you a pic. The car I restored had the interior changed out from white to black and the previous owner removed the striker plates on both the door and quarter and must have used the black windlace from a hardtop. I mocked up the cuts on these original black windlaces to lay out the cuts. They where a pain in the a$$ do to the fact that I had to cut thru the metal splines which must help pinch the windlace to the quarter lip. Sorry I can't help with the measurment that your looking for until I get back from vacation. I don't think there are many options for the white windlace for these year cars and I am very pleased witht the way these aftermarket ones came out after being sprayed with the pearl paint from YearOne. By the way, I had to call and ask for the pearl interior paint from them since it wasn't listed in there catalog.
69442murph
Jan 9, 2015 07:00 PM
507OLDS
Aug 22, 2013 07:40 AM
507OLDS
Oct 28, 2010 08:23 PM
silverriff
Mar 18, 2008 06:27 PM
71 Cutlass Convertible
Dec 10, 2004 12:18 PM
