Winter is coming and no heat
Old October 8th, 2015, 10:57 AM
wyocutlass's Avatar
68 supreme w/ac, The blower turns on and blows air but the heater does not kick on. I have done some research and I am trying to figure out if the heater valve is bad?, or if the heater core isnt getting anything in there, or a vaccum line. For the most part what is the main issue for the car not blowing out hot air?
wyocutlass is offline
Old October 8th, 2015, 11:23 AM
Heater valve broken, blocked, or not receiving right vacuum signal is the most likely.
I do not recall whether vacuum opened or closed the valve in your year, so you'll have to check your CSM.
After that, make sure the right vacuum is being applied.
After that, make sure that the valve is opening.
MDchanic is offline
Old October 8th, 2015, 12:25 PM
CutlassDad's Avatar
Thermostat?
CutlassDad is offline
Old October 8th, 2015, 12:26 PM
Oldsdruid
rocketraider's Avatar
Check:
1) coolant level, then check antifreeze concentration. You need at least 50/50 mix of antifreeze and water, both for freeze protection and proper cooling and heater operation.
2) if those are good, feel heater hoses. The one from back of intake to core should be HOT and core to water pump a little cooler. If block to core isn't hot, either the hot water valve is not working as Eric said, or there is some flow restriction in the heater core itself.
3) No vacuum hose is above suspicion. Make sure the storage tank to manifold vacuum line is intact and also storage tank to HVAC control (where it disappears into firewall).
4) Remote possibility of a bad selector or heater control valve on the HVAC head, after 45+ years. They were made of potmetal in those years and may have warped enough where the internal ports don't align.
Good luck.
rocketraider is offline
Old October 9th, 2015, 10:16 AM
wyocutlass's Avatar
Check:
Good luck.
The thermostat is brand new. Installed one few months ago. Radiator is also fresh with a new flush and new coolant. I did feel the hoses and one was hot and the other not so much. It was more on the cooler side. I am thinking my problem is there. Either a core or the valve. Is there a way to check the valve before going and buying a new one?
Old October 9th, 2015, 11:27 AM
Drain the antifreeze, take the hose off and see if you can spray water through it, in one direction or the other, with the vacuum in the correct state.
While you're at it, make sure water blows through the heater core properly.
MDchanic is offline
Old October 11th, 2015, 07:45 AM
wyocutlass's Avatar
I figured it out! Thanks everyone for the help. I had a missing vacuum hose. The heater blows great now. Thank you.
Old October 11th, 2015, 08:24 AM
In most cases its always the simple things.
oldcutlass is online now
Old October 13th, 2015, 01:01 PM
Well, 50/50 may be optimal for most situations but it certainly is not mandatory for anything other than freeze protection down to -34ºF.
Straight water (or any concentration of antifreeze/water) will still heat up to thermostat temp and give hot air out the heater, and it will also cool the engine adequately (actually a lower concentration of antifreeze has a higher heat capacity so it absorbs and transmits heat better). What a 50/50 mix does is reduce the freezing point by 66ºF, prevent corrosion, and increase the boiling point by ~15ºF.
I run 30% antifreeze in my car as that gives freeze protection to ~0ºF and our winter temps rarely ever get into the 20s, so no worries there; the higher water concentration provides more cooling capability during the summer; and the 30% gives me corrosion inhibitors.
But yeah, 50/50 mix is easy to do and gives good all around protection.
Fun71 is offline
Old October 13th, 2015, 04:00 PM
Octania's Avatar
That's some good scientific info right there
thanks for summarizing it.
Octania is offline
shamusj
December 24th, 2017 03:13 PM
Dream Whip
August 9th, 2016 02:59 PM
84oldsDelta88
20
January 12th, 2016 01:36 PM
smcurro
Paint
January 29th, 2012 02:31 PM
bjtstarfire
November 13th, 2008 02:04 PM
Quick Reply: Winter is coming and no heat
