Removing rear seat back part 1964/98 4dr
Old July 3rd, 2015, 12:59 PM
Jandk's Avatar
Can anyone tell me how to remove the back part of the rearseat ?
Jandk is offline
Old July 3rd, 2015, 03:40 PM
Rocketowner's Avatar
There should be 2 metal tabs,one on each side near the outer bottom corners of the seat back fastened (in some manner ) to the metal behind the seat back. Remove those and the bottom of the seat should pull toward you,then push up on the seat and it should come off the hooks that hold it at the top! Good luck, Larry
Rocketowner is offline
Old July 3rd, 2015, 08:10 PM
starfire's Avatar
You have removed the seat cushion, correct? You cannot remove the seat back without removing the seat cushion first.
starfire is offline
Old July 4th, 2015, 12:37 AM
Jandk's Avatar
Seat cushion is away, and is actually very easy to remove......
Those tabs are made of rather thing metal, and bends real easy. I tried with one of them, and I got the feeling it would break, if I should do this more than once, and then I stopped.
Jandk is offline
Old July 4th, 2015, 09:56 AM
I've took several of the seats out that had the tabs and never had one to break. The seat back will can not be removed until you get the bottom of it unfastened ! Larry
Old July 4th, 2015, 11:45 PM
Jandk's Avatar
Then I must give it a go.. If mine break... I must make some new ones
Jandk is offline
ddd777
April 5th, 2014 01:44 PM
richeyb
July 18th, 2010 07:44 PM
richeyb
June 27th, 2010 06:57 PM
pimps1002
Ninety-Eight
March 4th, 2008 07:30 PM
Chumley
November 10th, 2006 06:13 PM
Quick Reply: Removing rear seat back part 1964/98 4dr
