ID 1966-70 pedal firewall plastic
Old February 25th, 2023, 03:22 AM
omy442's Avatar
Continuing to sort 66-67 parts collection.
Found different firewall pedal plastic pieces.
All are slightly different. Just wanting to ID application before listing.
Mader
jm68442@yahoo.com
omy442 is offline
Old February 25th, 2023, 06:52 AM
Do the firewall plates have numbers molded into the backs of them? The 1967 window cranks are unique and one-year-only. Note in the lower RH corner of your photo that the dark colored ***** are 1967 window cranks. The yellowed clear **** is 1968-up. The 67 cranks have flatter ***** and thinner arms on the metal part.
joe_padavano is online now
Old February 25th, 2023, 08:34 AM
Loaded68W34's Avatar
Firewall plate #2 is 64-66 (rounded below column). #3 is 67 ("triangulated" below column). #1 is from a 68. Obviously 69-72 uses the wide plate pictured at the top left.
Loaded68W34 is offline
Old March 29th, 2023, 01:26 PM
omy442's Avatar
Thank you Joe P for the window crank ID help.
omy442 is offline
Old April 14th, 2023, 12:00 PM
omy442's Avatar
Sorry, Loaded68w34, I forgot to say thank you for the info !
omy442 is offline
Old April 14th, 2023, 05:57 PM
To add to a little more information, the reason for the change in 67 was that 64 - 66 simply used a rubber sleeve to support the column in the metal firewall mounting plate. 67 was the first year to use a "split-plate" that clamped the column to the firewall (part of the safety improvements in 67 so that the column would collapse in the event of a front end collision). The lower triangulated section on the plastic cover is there to provide clearence for the lower clamping bolt.
64 - 66 column mounting plate:
67 lower column mounting plate:
stellar
September 20th, 2018 06:23 PM
Niko
June 18th, 2013 07:07 AM
66ninetyeightls
Ninety-Eight
17
September 1st, 2011 01:17 PM
Mak
July 5th, 2011 05:52 PM
My442
May 2nd, 2010 04:24 AM
Quick Reply: ID 1966-70 pedal firewall plastic
