66 starfire wiper switch
Old May 2nd, 2014, 06:46 AM
bigretic's Avatar
anyone have a source for one or know what other gm part may be compatible? I have 3 wires under the dash for it, but the switch I found in the car (in the glove box) is a 2 wire connection, so I'm guessing I have a 2 speed motor with washer pump and the wrong switch.
thanks.
bigretic is offline
Old July 4th, 2014, 01:00 AM
cfair's Avatar
You should have a 2 speed wiper motor if stock.
The switch you need is common to 1965 and 1966 88's, 98's and Starfires. So are most of the dash parts like clocks,ignition switches, and radios. Scan eBay for a few weeks and one will turn up from someone parting these cars or selling NOS.
The correct switch has a plunger in the middle for the spritz feature, and three spade connectors on the back. Top is power in, bottom 2 are high vs low speed.
cfair is offline
Old July 4th, 2014, 06:11 AM
Octania's Avatar
I do have a 65 88 to part out, have not attacked the dash yet exc. the radio.
Octania is offline
bigretic
June 9th, 2014 08:37 AM
brandon reynolds
December 18th, 2013 03:05 PM
gwunta
August 30th, 2013 06:46 AM
toms1966rgtop
May 20th, 2012 07:55 PM
toms1966rgtop
May 15th, 2012 06:49 PM
Quick Reply: 66 starfire wiper switch
