1971 Console Painting
Old June 14th, 2016, 04:19 PM
geoff442's Avatar
I'm looking to restore a center console, I need some advice on paint selection and prepping the console. The console is brown in color and I want to paint it black. Any advice would on the console would be much appreciated.
geoff442 is offline
Old June 14th, 2016, 04:29 PM
For hard plastic parts I used SEM vinyl paint. Clean the parts very well to remove all dirt, grease, and oils, then spray them with light coats.
Fun71 is offline
Old June 14th, 2016, 05:32 PM
ELY442's Avatar
Originally Posted by fun71
for hard plastic parts i used sem vinyl paint. Clean the parts very well to remove all dirt, grease, and oils, then spray them with light coats.
x2
ELY442 is offline
Old June 15th, 2016, 06:46 AM
X3 on the SEM, however, you MUST get the plastic completely clean. Use a toothbrush or similar brush to scour the grain in the plastic. Once dry, use the SEM prep solvent before painting.
joe_padavano is offline
Old June 16th, 2016, 01:42 AM
geoff442's Avatar
Thanks for the advice, what type of black paint shoul I use semi gloss, or glossy.
geoff442 is offline
Old June 16th, 2016, 06:00 AM
allyolds68's Avatar
SEM Landau Black Part #15013
Here's the last one I restored. It was originally brown.
https://classicoldsmobile.com/forums...-restored.html
As Joe said, use the SEM prep and clean it well with a brush
allyolds68 is offline
Old June 18th, 2016, 03:00 AM
geoff442's Avatar
Thanks for the info it saves a lot of unnessary experimental work. What should I do with the metal moulding that wraps around the console, it looks like the tabs slide through then are bent to hold it in place. Can tha metal be polished ?
geoff442 is offline
Old June 18th, 2016, 05:37 AM
72 Olds CS
RetroRanger's Avatar
I think that aluminum price is anodized, it can be removed and re installed if your careful
RetroRanger is offline
Old June 30th, 2016, 07:08 PM
Shradezz70S's Avatar
I am restoring one converting it to a 4 speed. I removed that trim pice and sanded the plating off with 320. Then in worked finer 400,600,800,1500,2000 grit. Then rubbed it out with mothers and it looks perfect.
Shradezz70S is offline
bigmattg1
October 7th, 2013 02:05 PM
72notchback
February 22nd, 2013 06:49 AM
Prophe'c
October 22nd, 2010 09:16 AM
dallasite21
March 29th, 2010 07:54 AM
mv213
November 24th, 2009 10:32 PM
Quick Reply: 1971 Console Painting
