1968 Cutlass S inside Hood Release
Old January 2nd, 2013, 12:12 PM
tcarroll's Avatar
The Cutlass did not come with a inside hood release until 1970, does anyone know if one sold for a 1970-72 Cutlass will work? If not where can I get one that will work? Thanks.....T
tcarroll is offline
Old January 3rd, 2013, 09:28 AM
Uh, the 70-72 cars don't have an inside release either. They did have an optional inside hood lock mechanism, but this requires the correct latch on the core support, which will not fit your earlier car. The hood lock simply tripped a lever in the latch mechanism on the core support to prevent the external latch from working. If you care about security, consider a cable and padlock that is accessed from under the front of the car.
joe_padavano is online now
Old January 3rd, 2013, 09:34 AM
Octania's Avatar
One trick I have seen- remove clip from receptacle hole for lower end of vertical rod from finger lever to latch. Leave rod out of hole until you need it. It'll seem to be broken, to the intruder.
I just thought of a clever enhancement- place a magnet nearby, a bit aft, to hold the lower end of the rod almost out of reach. Only the wise will be able to get past that quickly.
If your concerns go beyond that, perhaps it needs an attention getter that makes noise and/or summons you if the hood gets opened.
Octania is offline
Old January 3rd, 2013, 10:15 AM
tcarroll's Avatar
Thanks guys I'm actually looking at a cable with a metal rod that will secure the hood to the top of the radiator support. Still looking and researching.
tcarroll is offline
RandyS
February 14th, 2014 06:44 PM
borrone821
January 23rd, 2014 01:37 PM
Gary M
January 19th, 2014 10:09 AM
costpenn
November 28th, 2012 09:33 AM
tcarroll
February 24th, 2012 06:32 AM
Quick Reply: 1968 Cutlass S inside Hood Release
