69 hurst olds
69 hurst olds
two questions
1. H/O 455 stickers. I know theres a left and right but what is the spacing from the front edge of scoop to the H on the drivers side and front edge of scoop to the last 5 on passenger side, aslso spacing from the top of the scoop down to the top of the H's
2. vacuum line routing for top had breather. need to know where and how the big vacuum motor is ran. where does it come from intake or carb and then how does in run into the the vacuum motor actuator. my old breather bottom has a vacuum switch mounted in the bottom, to run actuator for manifold heat box.
Thanks for any help you can give.
1st question http://www.supercarsunlimited.com/in.../catalog18.pdf
1969 Hurst/Olds Paint Layout
Layout instructions for the 1969 Hurst/Olds Firefrost Gold paint stripes.
This hand drawing is a bit rough, but is well detailed and complete. Including
exterior emblem placement..................PART NUMBER 01-290..PRICE: $15.00
67442nut
September 16th, 2017 01:23 PM
July 26th, 2015 03:02 PM
Joffroi
Hurst/Olds
July 17th, 2012 05:44 PM
ccnclassicoldsmobile
June 8th, 2012 03:53 AM
brad442
December 23rd, 2011 08:11 AM
