1972 Cutlass Hurst Dual Gate Shifter Questions
Old January 4th, 2011, 07:09 PM
oldfarmall's Avatar
Exclamation 1972 Cutlass Hurst Dual Gate Shifter Questions
Hello-
I am in the process of fixing up my 1972 Cutlass and want to install a Hurst dual gate shifter. Have a couple of questions regarding this.
1. What years was the Hurst dual gate shifter the same for Oldsmobile. I heard 1970-1975 shifters were same, just different brackets and top plates?
2. I see The Parts Place offers a complete Dual Gate unit for $600.00. Anyone have any experience with this shifter from them, is it aftermarket china crap or is it still made by Hurst and is it idenicle to the original?
3. Are there any other dual gate shifters that are compatable to the 1972 Oldsmobile Hurst Dual gate, such as Pontiac or other era GM cars that can be made to work by changing brackets and top plate, etc. ?
I want to learn as much as I can with this project and not buy junk without overspending on the wrong shifter. Figured many other Olds fans would have some great input. Thanks for any help in advance. It is much appreciated!
oldfarmall is offline
Old January 4th, 2011, 07:16 PM
firefrost gold's Avatar
70 71 72 would be the same , The parts place and original parts group inc
also has a new set up ad for other makes the pontiac has a straight shifter handle and olds has a curve to it at least in the a body floor pan that would
work with your car.
firefrost gold is offline
Old January 4th, 2011, 08:27 PM
2blu442's Avatar
Many many years ago I picked up a 1968 GTO dual gate. I wacked the 1970 Olds console to make it wide enough for the much wider top plate. Looked kinda tacky, but I didn't know any better...
So you might check the width if you come across anything that's not made for the Oldsmobile. John
2blu442 is offline
Old January 4th, 2011, 09:04 PM
Cameo White's Avatar
Smile
Hey John,
That 68 GTO dual gate top plate was probably the correct width for the 68 and 69 H/O. Much wider than the 70-72 version.
Cameo White is offline
Old January 4th, 2011, 09:37 PM
2blu442's Avatar
I didn't think about it being similar to the 1968-69 Olds top plate size!
2blu442 is offline
Old January 5th, 2011, 06:38 AM
Note that Pontiac dual gates use a straight stick, Olds dual gates use a "bent" stick.
joe_padavano is offline
Old January 5th, 2011, 06:34 PM
Smile
As Joe noted, the stick has a different shape between the Poncho and the Olds, but the top plate in 68/69 was the same size, as far as I can tell. They had different fake wood applique's, though.
Old January 6th, 2011, 04:31 AM
ziff396's Avatar
[quote=oldfarmall;240386]Hello-
I purchased one from The Parts Place. Beforehand, I inquired into it. They told me that they had purchased all of the NOS parts that Hurst and anyone else (most) had, and these were assembled from those. Once I recieved it, I compared it to my original one that needed restored. I could not tell any difference between the two whatsoever. I'm happy with it.
ziff396 is offline
Old September 10th, 2012, 09:05 AM
Tony72Cutlass'S''s Avatar
[QUOTE=ziff396;240789]
Originally Posted by oldfarmall
Hello-
DO you have any pictures of this shifter installed in your car?
I built a car for my dad, and he wants me to install a dual gate shifter for him.
I'd rather keep the bench seat in my car. So the setup from parts place seems pretty good.
Tony72Cutlass'S' is offline
Old September 10th, 2012, 10:22 AM
Mr. Johnson
rjohnson442's Avatar
I have an original dual gate out of a 72 with the top plate. Good condition need a new cable and ****. I might let it go for the right price. PM me if interested
rjohnson442 is offline
Old September 10th, 2012, 12:31 PM
Thanks for the offer but I'm not putting a console into my car, it'd probably be better to put your dial gate towards someone doing an authentic restoration.
If you put yours in the for sale section, these things sell like hot cakes!
Old April 28th, 2013, 08:06 AM
anthonyP's Avatar
In addition to the wood grain difference, the '70 dual-gate is different than the '71/'72 dual gate.
anthonyP is offline
Old March 12th, 2014, 08:55 PM
69CutlassAlex's Avatar
Do you know if the 70 top plate will work with the 68 GTO HDG in terms of the actual gates and not the size of the plates themselves?
69CutlassAlex is offline
Old March 13th, 2014, 05:56 AM
BlueCalais79's Avatar
Check out e-Bay, they have some decent used Dual Gates for a 70 -71- 72 Cutlass
BlueCalais79 is offline
Old November 26th, 2014, 05:32 PM
89biff's Avatar
Hurst dual gate
Was the dual gate available in 67 442? Does anyone know if it would fit?
89biff is offline
Old May 15th, 2016, 05:01 AM
No it was not. . Yes you could buy one from Hurst
Old February 9th, 2017, 04:41 PM
The Rocket Astronomer
lunaboy's Avatar
please could you tell me the difference as i have one and think its a 70
lunaboy is offline
Old February 9th, 2017, 05:08 PM
4speed455's Avatar
70 would have the neutral safety switch mounted on the shifter. 71-72 have it on the column. When I converted my car from column shift to floor shift I just used the column mounted switch since the 70 switch is hard to find and not cheap.
4speed455 is online now
Old February 9th, 2017, 05:31 PM
classicmuscle442's Avatar
Back to the future, 2011
classicmuscle442 is offline
Old February 9th, 2017, 05:34 PM
lunaboy's Avatar
thx 4speed455 thats exactly the info i needed ... I thought the switch was missing on the nice 71 72 unit i have but was able to make a good 70 unit by moving the bracket and neutral safety switch from a true 70 unit i just purchased.
lunaboy is offline
Old February 9th, 2017, 06:26 PM
lunaboy's Avatar
found the 70 neutral safety switch and bracket aftermarket pic. but don't think they are avail anymore. from goodolddays - mike siedlik
lunaboy is offline
Old February 9th, 2017, 06:46 PM
oldsmobiledave's Avatar
Fyi
That is who I bought mine from. Excellent parts and customer service.
oldsmobiledave is offline
Old February 9th, 2017, 08:42 PM
stevengerard's Avatar
He still has the NSS brackets
http://mikes442.com/products
stevengerard is offline
Old April 27th, 2022, 12:40 PM
tkcutlass's Avatar
I know this is an old post, does anyone know how to get a 70 NSS bracket?
tkcutlass is online now
Old April 27th, 2022, 03:34 PM
72 Olds CS
RetroRanger's Avatar
the parts place has the switch and a bracket IDK if its the bracket
https://www.thepartsplaceinc.com/pro...-bracket/54623
RetroRanger is offline
Old April 27th, 2022, 08:39 PM
tkcutlass's Avatar
Perfect exactly what I was looking for Thanks!
BeenThere
July 1st, 2015 01:18 PM
fast67vellen2o
June 9th, 2012 03:31 PM
oldfarmall
Hurst/Olds
February 28th, 2011 11:48 AM
oldfarmall
January 20th, 2011 09:46 AM
Quick Reply: 1972 Cutlass Hurst Dual Gate Shifter Questions
