1984 HO issue
Old November 6th, 2016, 02:51 PM
deaddds's Avatar
1984 HO issue
My problem is the gauges are not working. Local guy showed me how to clean the contacts on the back side and rlug in the cluster. Replaced all the bulbs at the same time. Bulbs work. Gauges did not. Then the water pump shot craps so I pulled all the stuff in the way to get the pump out and fixed that. While testing I noticed the gauges worked correctly. Later this afternoon they did not work again. Is this a ground issue? If so where is the ground so I can sand it off for better ground relative to the gauges? Any info is appreciated.
deaddds is offline
Old November 6th, 2016, 04:32 PM
Lansing built
1970cs's Avatar
If memory serves. The area where plug that flexible strip is losing contact. I used electrical tape to build up the area to put some pressure on the plug.
Pat
1970cs is offline
Old November 7th, 2016, 05:21 AM
deaddds's Avatar
Did you tape the cluster side or the contact in the dash?
deaddds is offline
Old November 7th, 2016, 05:43 PM
Lansing built
1970cs's Avatar
You taking me back 17 years ago! My memory has faded?
Pat
1970cs is offline
Old November 7th, 2016, 05:52 PM
deaddds's Avatar
Wink
What you don't write this stuff down?
deaddds is offline
1yesfan
August 4th, 2015 06:40 PM
Dead Reckon
July 14th, 2014 02:35 PM
Perry615
April 16th, 2013 05:55 PM
bulletproof
March 14th, 2012 09:58 AM
<terrys692@yahoo.com>
July 3rd, 2004 09:53 AM
Quick Reply: 1984 HO issue
