Manifold heat riser tube
Old December 18th, 2014, 02:38 PM
JpMotorsports's Avatar
Currently the heat riser tube is not on my 72 cutlass. I was looking at how it mounts and see two small holes (one on top and one on bottom) How is this mounted?? Is it mounted to the air cleaner or the bracket on the manifold?
JpMotorsports is offline
Old December 18th, 2014, 02:45 PM
drop top olds's Avatar
One bolt to the circular flange under the air cleaner inlet. Another small bolt that fastens the heat riser tube to the exhaust manifold shroud (or on a BBO a "box" type shroud).
drop top olds is offline
Old December 19th, 2014, 06:37 AM
Are these bolts avail or just use a general bolt that will fit?
Old December 19th, 2014, 07:15 AM
72 heat tube has 2 holes in the base that mate with 2 holes in the manifold cover. These holes are in a straight across line from each other instead of at 90* like in 71. It's attached with a long cotter pin, unlike the 71 model which used 2 small bolts to hold it in place. The snorkel end of the heat Tibet is not screwed on or pinned. It's held in place by friction created when the air cleaner is tightened down.
Allan R is offline
88hurstolds
November 14th, 2014 12:07 PM
dingusboy
March 8th, 2014 07:09 AM
1977 Delta 88 Flint
December 24th, 2012 11:25 PM
oldspackrat
December 6th, 2012 02:48 AM
bjtstarfire
November 13th, 2008 02:04 PM
Quick Reply: Manifold heat riser tube
