choke not working
Old Aug 25, 2009 | 10:01 PM
1973olds98's Avatar
choke not working
Does anyone have a diagram of the choke assembly on a 1973 rochchest 4 bbl carb..My choke is not working when i bought the car...I didnt know it until i got it home..The arm of the choke has a wire threw it tied down so it will not operate..I unhooked the wire and gave the car some gas and the arm kicked up and the plate closed on the front part of the carb..The problem is it never kicks off....
Old Aug 26, 2009 | 06:22 AM
IF the choke never disengages then you need to reset it. Loosen the three screws on the choke plate and use a screw driver to turn the choke in its housing until you get the choke plate to move. Do this with the engine cold. When the choke plate moves make sure it is closed with only a little bit of space between the choke plate and the body of the carburetor. Then retighten the three screws.
Old Aug 26, 2009 | 06:54 AM
1973olds98's Avatar
So i turn the black cap in clockwise?
Old Aug 26, 2009 | 07:13 AM
1973olds98's Avatar
OK,,,its counter clockwise right? I move it in counter clockwise with the motor cold just until the choke plate closes on the carb
Old Aug 26, 2009 | 09:42 AM
Moving it clockwise or counterclockwise a bit should cause the choke plate to move a bit. Just move it whichever direction causes the choke plate to close.
Old Aug 26, 2009 | 09:54 AM
1973olds98's Avatar
OLDS64
thanks man,,,I got it reset and it work now...Should the choke plate be straight up and down when the engine has warmed up...Mine is opening as it gets warmer but dosent go straight up and down...
Old Aug 26, 2009 | 09:57 AM
The choke plate will eventually open up completely but you have to "blip" the throttle to deactivate the fast idle cam. It may take a minute or two.
Old Aug 26, 2009 | 10:49 AM
1973olds98's Avatar
Yep,,its working,,,,,So basically if you turn the black cap more it will take longer for the thermostat spring to open correct? How high should it idle when the choke is on...? And what should the idle be when the choke is off
Old Aug 26, 2009 | 12:54 PM
No. Changing the position of the black choke cap causes the choke valve to move. This allows you to close the choke when the engine is cold. Remember that your choke valve will end up more open or closed once the weather changes. The position of the choke plate is dependent upon the bi-metallic spring inside the choke. This bi-metallic spring is swedged onto the black choke cap and wraps around the bottom of the choke rod.
You set your fast idle to determine the idle speed in park with the throttle plates on the lowest step of the fast idle cam. Set the slow idle with the choke disengaged to determine your idle speed in drive.
240 Gordy
Oct 11, 2020 10:04 AM
Octania
Apr 15, 2015 02:29 PM
70redvert
Dec 3, 2007 07:26 PM
Calvin.Norris
Nov 27, 2007 06:08 PM
<KEN>
Sep 22, 2004 08:39 PM
