Front and rear springs for 61-62 full size
Old Jan 25, 2009 | 09:26 PM
NAS Backyard's Avatar
Has any one ever replaced there front or rear springs on their cars and if so, which ones did you use and where did you get them? Rock Auto lists front ones but no rears . I can bottom out my front ones almost by hand. Also need a cross reference for shocks if possible. Thanks
Old Jan 26, 2009 | 04:31 AM
I purchased shocks for my 64 Olds 98 from Fusicks years ago. They also carried front and rear springs but I decided not to replace mine. I did however purchase a front end kit from Kanter and replace the bushings and ball joints.
Old Jan 26, 2009 | 08:41 AM
nohn's Avatar
I replaced my front and rear springs. I went the after market route and go the Hotchiks suspension kit. It cam with front and rear springs and front and rear sway bars. I purchased it from Summit. I didn’t see anything for 61-62.
Old Jan 26, 2009 | 12:04 PM
68Tom's Avatar
Just ordered a set of front springs from Fusick's (you can also get rear springs there as well). I like the fact they are cut to specifics for your Olds (cut to order), unlike many other parts houses that are for the wide range of GM cars (all A-bodies, for instance). Should give the proper ride heighth to your vehicle.
jaunty75
Dec 11, 2016 07:53 PM
steve walker
Jun 21, 2014 06:17 AM
KQQLCAT
Drivetrain/Differentials
Oct 18, 2011 11:19 AM
jaunty75
Apr 30, 2011 04:09 PM
Delmont 88 425
Oct 2, 2010 08:52 AM
