left turn signal control
Old April 4th, 2011, 04:12 PM
fmbjogger's Avatar
The left turn signal on column won't engage and " click in". Light works and no trouble with right hand turn. What's the problem ?
fmbjogger is offline
Old April 4th, 2011, 08:50 PM
svnt442's Avatar
The canceling cam probably bit the dust. You're probably going to have to pull the steering wheel and lock plate to replace it.
svnt442 is offline
Old April 4th, 2011, 08:57 PM
+1.
Junkyard part, or you can buy one new at the corner parts store.
Not hard to change out, but the steering lock plate is annoying on a '69 and later if you don't have the tool (I'm too cheap to buy the tool...).
MDchanic is offline
Old April 5th, 2011, 07:41 AM
Actually, the more common problem is that the cancelling spring breaks. You can get replacements from Dorman Products (P/N 49312).
joe_padavano is online now
Old April 5th, 2011, 08:06 AM
Are you sure, Joe? He said that the switch wouldn't click into the "on" position in one direction, not that it wouldn't cancel.
I believe that in this case, the detent spring has gone (cracked switch body), thus preventing it from clicking in, but still allowing the contacts to turn the light on.
Easy enough to see whether the cancel spring is lying in the bottom when he pulls the wheel anyway...
MDchanic is offline
Old April 5th, 2011, 09:13 PM
svnt442's Avatar
That's why I didn't go for the spring.
svnt442 is offline
Old April 11th, 2011, 06:10 AM
fmbjogger's Avatar
Pulled the wheel and it's a broken cancelling cam. Thanks to all for the excellent advice !
gofastdontcrash
August 9th, 2015 10:49 AM
costpenn
June 24th, 2015 10:38 PM
Herv Purcell
August 31st, 2014 02:22 PM
oldschool780
May 7th, 2013 06:14 AM
PGH Cutlass
September 29th, 2011 05:29 AM
Quick Reply: left turn signal control
