Best engine break in oil
Old July 24th, 2015, 11:33 AM
stanzaschance's Avatar
Cool Best engine break in oil
I just had my 1966 olds 330 engine rebuilt. But I'm trying find out what would be the best break in oil along with the best oil to continue using on a daily basis. Thanks any information would be greatly appreciated!
stanzaschance is offline
Old July 24th, 2015, 11:49 AM
I use 4 quarts of straight 30w non detergent, what evers cheap, and add a quart of GM EOS. I break the cam in and change after 100 miles. I run Valvoline VR1 Racing Oil 10w30 after that with WIX filters.
oldcutlass is online now
Old July 24th, 2015, 11:53 AM
RonFX's Avatar
Hello:
I would use an oil or additive that is correct for a New Cam Break in period, I purchased an additive for the oil I used for my break in. Summit or Jegs should be able to help with whatever you need, it is possible that the Box Auto Parts stores may also have something for you. Make sure that you get something that IS recommended for New engine break in, after that use whatever you have good luck with in the past, such as Kendall, Valvoline, Havoline and Quaker State just to mention a few, there are many others as well. See, answering the question wasn't that hard.
Thanks, Ron
RonFX is offline
Old July 24th, 2015, 12:55 PM
68442's Avatar
Comp Cams make an oil specific for new engine break in. Has all the additives required. I have used it on numerous engine break in's with no failures
68442 is offline
Old July 24th, 2015, 01:21 PM
Professur's Avatar
Is it really so wrong that when I hear 'break in oil', I automatically think Dungeons and Dragons ... carrying oil so the door hinges won't squeak when you're skulking about?
Professur is offline
Old July 24th, 2015, 01:35 PM
Beer Connoisseur
70cutty's Avatar
I always used Joe Gibbs break-in oil.
70cutty is offline
Old July 24th, 2015, 01:43 PM
Actually, yeah, it is...
joe_padavano is offline
Old July 24th, 2015, 02:11 PM
ELY442's Avatar
X2, I use the Comp Cams break in oil along with 20w50. After 100 miles, I drain the oil and change the filter and add 20w50 with a bottle of ZDDP.
ELY442 is offline
Old July 24th, 2015, 02:32 PM
Stefano's Avatar
We use Brad Penn break-in oil on all of our builds.
The viscosity is dependent of the clearances and/or specific parts used in the build.
Stefano is offline
Old July 24th, 2015, 04:55 PM
morgan
pogo69's Avatar
I used accel 10-40 (SF rated high zinc level, was sold at walmart havent seen it lately) for break in and after 100 miles put accel 10-40 back in... no break in additive this time around as I used Tech Line coatings on camshaft/pistons/oil pump gears,all bearings and other parts
pogo69 is offline
Old July 26th, 2015, 06:07 PM
Just the facts...
BILL DEMMER's Avatar
i used 5 qts. 10W40 citgo(used to be the factory fill, back in the day) and 1 bottle(pint) of GM EOS.
bill
BILL DEMMER is offline
Old July 27th, 2015, 03:23 PM
Mostly Gristle
bluecab's Avatar
The machine shop that does my motors uses Brad Penn break in oil.
bluecab is offline
scooter123
April 14th, 2013 08:41 AM
1970455sx
November 28th, 2010 03:58 PM
1973olds98
Drivetrain/Differentials
August 17th, 2010 11:48 AM
AZ442
September 23rd, 2009 07:16 PM
Quick Reply: Best engine break in oil
