AC wiring questions
Old December 15th, 2016, 02:57 PM
My2nd 69 442's Avatar
AC wiring questions
Today I'm reinstalling my resealed AC compressor and I have a concern with a relay for the clutch wiring.
I do not have a AC relay on the pax side fender well. The connector that I believe should connect to the AC relay has a Green and a Brown wire in it. The grn wire then continues to the hot side of the AC clutch. Clutch grounds to case mount at the clutch plug. brn wire goes to nothing. Connector is 2 wire L shaped.
The AC worked ok before dis assembly as it is currently wired.
My questions are do I need the relay and if I do need it how does it wire?
My CSM is nearly unreadable for the wiring diagrams.
Any help will be appreciated
My2nd 69 442 is offline
Old December 15th, 2016, 03:03 PM
Aw, c'mon, it's not that hard to read:
Your hold-in relay is missing. The A/C will work fine without it, but you lose the ability to run the compressor with the defroster.
MDchanic is offline
Old December 15th, 2016, 03:35 PM
Thanks Eric
I sure wish that I had diagrams as good as the ones you have.
Since I cant imagine needing the defroster while running the AC compressor here in Arizona, I think I'll leave well enough alone.
Old December 15th, 2016, 03:49 PM
You're welcome.
If you want a legible manual, just go join the Automotive History Preservation Society for about $25 to download a huge amount of material, or buy an original copy on line ('69 is popular, so could be $40 or more).
MDchanic is offline
miked
June 14th, 2012 06:02 AM
oldsonharmont
October 16th, 2011 02:16 PM
oldzy
September 10th, 2009 05:23 AM
TIREGUY
December 16th, 2006 04:10 PM
stuart
August 14th, 2004 02:24 PM
Quick Reply: AC wiring questions
