442 VIN and body tag
Old January 26th, 2017, 05:37 PM
EngineErnie
EngineErnie's Avatar
I have a 1968 442 convertible (by VIN) but the body tag codes as a regular cutlass
How do I know this is a true 442 convertible even if the body tag says otherwise
I'm not able to upload photos but the relevant info is below:
VIN 344678M3708xx
Body tag 68-33667 LAN 376600
The VIN and body tags don't look to be molested or altered
EngineErnie is offline
Old January 26th, 2017, 07:52 PM
2blu442's Avatar
Since your vin has the correct numbers for the 442 your fine. Its been well documented that in 1968 442's were built with the trim tag located on the firewall using the Cutlass number not the 442 number. John
2blu442 is offline
Old January 26th, 2017, 08:24 PM
stevengerard's Avatar
As John said, your VIN says its a 442
stevengerard is online now
Old January 27th, 2017, 09:08 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Common well documented subject here. Do a search(s). The hull manufacturer, Fisher Coach Works, didnt care if it was a Cutlass or a 442. So most Olds Cutlass A bodies coming from Fisher indicated 336. It was turned into a 442 at the Olds plant where it obtained its VIN tag. I say most because a few of them did get 344 Fisher tags at other plants such as Fremont. My 68 442 Fremont Z code car has 344 on the firewall and VIN tag.
droldsmorland is offline
Old January 27th, 2017, 10:54 AM
EngineErnie
What sources of publications out there discuss this?
Old January 27th, 2017, 01:06 PM
The Fisher Body Manual for both 1968 and 1969 specifically mentions this issue on Oldsmobile A-body cars in the front section. The model and body style table in the parts book also documents this, as I've posted below. Note the footnote in the middle of the RH column.
joe_padavano is offline
Old February 11th, 2017, 12:07 PM
EngineErnie
Thanks Joe. Can you rescan and post the left side of that page with the numbers of the high performance V8?
Old February 11th, 2017, 03:48 PM
Here ya go.
ironlou399
August 9th, 2019 01:08 PM
Octania
February 10th, 2015 10:51 PM
knoggin
April 17th, 2014 01:48 PM
Parting-out-a-olds
January 6th, 2011 04:06 PM
DesertToro
January 16th, 2007 07:10 PM
Quick Reply: 442 VIN and body tag
