Frame Off
Old Nov 17, 2008 | 04:56 PM
Gary's 2 442-S's Avatar
Gary
Frame Off
Has anyone personally done a frame off themselves? If so was it very difficult to remove from the frame. I have 72 442 and have done a replacement of the quarter panels and the trunk. Also if you did the remove the frame did you build body dolley or buy one
thanks Gary
Old Nov 17, 2008 | 05:26 PM
Willidog's Avatar
Official Tire Kicker
I did a frame off in my drive way. I raised the body up enough with regular floor jacks to slide 4X4s under the body at the front and rear and then I used those big farm jacks to raise the body enough to roll the frame out from under the body. As I raised the body I was supporting it with building blocks by moving it up enough to put one block in the rear, then one block in the front till I had stepped it up high enough to get the frame out. Once the frame was out I put additional blocks in the middle of the 4X4,s for added support while I worked underneath it. I already had the new frame ready in the garage so as soon as I had the floorpanels done and painted I just rolled the new frame under it and lowered the body onto it. Took about a week and you need three or four guys while raising and lowering the body, two guys for the jacks, one safety observer and maybe a guy to help steady the body while it goes up/down. I think there is a picture of it here on the board some where so check other threads that I have posted to to see them. Here is a link to the thread with the pictures: https://classicoldsmobile.com/forums...r-new-guy.html
Keith
Old Nov 17, 2008 | 05:49 PM
Gary
Wow! That was very imaginative. Never would have thought to do it that way. A friend of mine suggested that I build a body dolly and get about 4 or five other friends to help lift it off. He said that he had built a body dolly out of 2x4's also using caster wheels. I think I will use angle iron to build oneI want to sand blast the frame which I had done much of it already by jacking the car up high and painting it with Por 15,but I cant get all the places I need to get to. I have also purchased a body bushing kit. I think seeing what you did is giving me inspiration to remove the body.
thanks
Old Nov 17, 2008 | 07:35 PM
gearheads78's Avatar
car guy
Iv'e got the ongoing 66 on the lift but also recently picked up a 64 GTO project and it came with a simple 4 x 4 and 2 x 4 roll around cart the other owner made.
Old Nov 18, 2008 | 04:08 AM
Letting some air out of the tires makes it easier to get the frame out w/o jacking it up too high
Like the snow tires
Impin'
Body work
26
Feb 15, 2012 02:47 PM
sixty9olds
Jun 14, 2011 06:43 PM
shawn neal
Mar 6, 2009 07:57 PM
Want-A-Vert
Mar 30, 2007 08:00 PM
DJMatthews
Dec 5, 2006 01:28 PM
