Best gasket sealer
Old April 18th, 2013, 06:14 PM
Sampson's Avatar
Best gasket sealer
I went to the local parts place today to pick up some supplies in preparation to put my 355 back together. I started looking at gasket sealers and times have sure changed. There was red, blue, copper, black, ultra black.......thermostat, differential exhaust........the list goes on and on. The last time I did this I had a tough time choosing between Permatex 1 or 2. One thing that I have learned over the years is that everyone you talk to has a different thought on installing gaskets. Sealer on 1 side, sealer on both sides, no gasket just sealer, no sealer just gasket etc. Heck when I tore this engine down the previous builder had put red Permatex on every bolt thread including the head bolts. I was wondering if you guys would be willing to share some of your best practices for preventing leaks. How about the rope main bearing seal vs the rubber seals?
Sampson is offline
Old April 19th, 2013, 04:58 AM
m371961's Avatar
I like something called THE RIGHT STUFF. Very good for aluminum intake end seals, using no gasket. Similar to what current makers are using instead of gaskets.
m371961 is offline
Old April 19th, 2013, 05:45 AM
morgan
pogo69's Avatar
I use the perm. aviation form-a-gasket sealant liquid on just about everything...the longer it sits in the container the thicker it gets...also have used the neoprene seals with no problems. ...your right now a days there are are way to many choices
pogo69 is offline
Old April 19th, 2013, 01:33 PM
jag1886's Avatar
I have used Ultra Black on everything that needs sealer except rear ends for years, it's easy to use takes very little to get the job done and lasts.
jag1886 is offline
Old April 19th, 2013, 02:17 PM
Hylomar.
Nectar of the gods.
MDchanic is offline
Old April 19th, 2013, 02:53 PM
Sampson's Avatar
I guess it says a lot if it is good enough for airplanes!
Sampson is offline
Old April 19th, 2013, 03:21 PM
Justin
oldstata's Avatar
Depends on the job ,for intakes I like the right stuff black
For valve covers and oil pans . I like Fujii bond from Subaru have not seen one oil pan leak with this stuff so I started using on some gm pans so far so good
oldstata is offline
Old April 19th, 2013, 07:23 PM
442rocketdave's Avatar
I agree with MDMechanic Hylomar racing formula is the best!!
442rocketdave is offline
Old April 19th, 2013, 09:27 PM
davebw31's Avatar
Right Stuff for silicone apps, such as end seals in the corners of frt. and rear intake seals, end seal at frt timing cover and rear main oil pan seal in the corners
Perm. Aviation Form-A-Gskt. liquid or High Tack Gskt. spray for all gaskets. I use these products on both sides for steel head gskts. and have never blown a head gskt.
davebw31 is offline
Sampson
April 18th, 2013 06:06 PM
harry k
November 21st, 2012 08:54 AM
Lady72nRob71
April 1st, 2011 05:13 AM
dallasite21
June 20th, 2010 05:37 AM
Sixoh
August 8th, 2006 05:11 AM
Quick Reply: Best gasket sealer
