1955 Olds Hydramatic Question
Old February 27th, 2013, 08:07 AM
Olds Scott's Avatar
No battery in car at this moment so I can't check if dash indicator is working. Since I am about to unstick engine (hopefully); should the position of the column shift be in the up position or the down position. Car is up on jack stands with tires removed so I can't roll the car.
Olds Scott is offline
Old February 27th, 2013, 09:13 AM
bajaway's Avatar
all the way up on selecter is neutral. All the way down is reverse and locked in as a park position would do. Good luck on engine!
bajaway is offline
Old February 27th, 2013, 09:19 AM
Olds Scott's Avatar
Thanks for the information bajaway.
d2_willys
February 4th, 2015 07:24 PM
Bikes&Rods
May 7th, 2012 08:17 PM
Mad Scallywag
18
April 20th, 2012 09:06 PM
American Lead
24
March 17th, 2009 07:48 AM
Jet Doc
November 2nd, 2008 11:55 AM
Quick Reply: 1955 Olds Hydramatic Question
