Msd distributor coil wiring help
Hey all, I have a msd distributor in my car, was stock coil, I bought a msd blaster coil..before I installed it I checked and the resistor wire and yellow factory striped wire showed 12 volts using a volt meter.( these two are connected to one clip that goes to coil) So I hooked it up like a factory coil, horrible time starting, dieseling etc. i ran a jumper wire from the battery to the coil just to check ..car ran fine.. so I ran a wire from the ignition switch to the positive coil and disconnected the resistance wire and the yellow striped wire that attach to a clip to go to the coil.. took it out for a drive, runs well so far.. My question is did I do this correctly? Do I need to hook up the striped wire that is attached to the factory resistance wire for any reason? Appreciate any help
