455 Dipstick
Old May 13, 2009 | 10:17 AM
tim72's Avatar
455 Dipstick
I am having a problem figuring out how to insert a new dipstick on my newly rebuilt 455. The dipstick has two sets of rings that act as a gasket inside the dipstick tube hole. Is there a special tool to press this dipstick in? I was thinking about using heat and a small crows foot with an extention I can attach to tap on. any sugestions?
Tim72
Old May 13, 2009 | 10:29 AM
Tim72
The official Kent Moore tool is a length of steel tubing with an ID that just slips over the dipstick tube and bears up against the shoulder. 180 degrees of the tool is cut away for about 6-7 inches so it can fit onto the dipstick tube. You hammer on the top.
I've used the "open end wrench" method as well as the "long flat blade screwdriver" method and ruined more than one dipstick tube as a result.
I'm not a fan of sanding down the beads and gluing the tube into the block.
Old May 13, 2009 | 11:54 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I use 2 small hose clamps around the upper part of the base and beat on the big clamp bosses with a long screwdriver.
Old May 13, 2009 | 12:13 PM
Has anyone ever put the dipstick in the freezer first?
Old May 13, 2009 | 05:03 PM
442Harv's Avatar
I have put it in the freezer, than I put a screw or small bolt, in the oppening, and tap it in.
dantecl
Oct 27, 2013 02:50 PM
Jolly Green
Jan 16, 2013 05:07 PM
zodiacblueS
Sep 2, 2011 04:01 PM
1964F85
Aug 7, 2010 07:25 PM
suppressivefire
Oct 29, 2009 04:15 PM
