removing the rear seat
Old August 1st, 2013, 10:29 AM
chip-powell's Avatar
Silly question, but it's been several years.
I will be replacing the carpet in my '71 cutlass convertible this weekend. How do you remove the rear seat? So far, I have been unable to find any bolts that I can reach (like the ones on the front bench seat). I know that I am missing something obvious and it's driving me nuts.
chip-powell is offline
Old August 1st, 2013, 10:39 AM
The bottom structural wire in the lower seat frame is captured by two sheet metal hooks welded to the floor. You need to press down and rearward on the lower cushion to disengage the hooks, at which point you can lift the leading edge up and pull it out. The seat back is held with bolts at the bottom (visible with the bottom cushion removed) and hooks at the top.
joe_padavano is offline
Old August 1st, 2013, 10:52 AM
Thanks. Are those hooks located in the 2 front corners of the seat or towards the middle? Just in case they're stuck (I have no idea when this seat was last removed), I want to make sure that I am pressing in the right place.
Old August 1st, 2013, 11:05 AM
About a foot inboard on either side.
Old August 2nd, 2013, 04:01 AM
Thanks again
Old August 2nd, 2013, 04:34 AM
Past Administrator
Oldsguy's Avatar
It helps if you are a smaller person. I originally used to cram myself in the foot well area behind the front seat, facing backward and then pushed to release the bottom cushion as Joe described. When I got too big to do it that way I had to figure out an alternative way to do it which just required more muscle.
Oldsguy is offline
Old August 2nd, 2013, 04:52 AM
Oldsmobile enthusiast
s i 442's Avatar
That was a set up they should have used as seat belts!!! I like to broke my back last weekend pushing that seat bottom down and back at the same time and cramped up behind the front seats!!!!!
s i 442 is offline
Old August 2nd, 2013, 06:45 AM
brown7373's Avatar
At 6' 4", I always remove the front seat(s). For me, it is difficult to impossible to remove the rear seat with the fronts in.
brown7373 is offline
rctoyguy
April 10th, 2016 07:02 AM
Jandk
July 4th, 2015 11:45 PM
Klayfish
June 17th, 2011 08:29 PM
richeyb
June 27th, 2010 06:57 PM
Chumley
November 10th, 2006 06:13 PM
Quick Reply: removing the rear seat
