Question: "Propeller Shaft"
Old March 20th, 2012, 11:47 AM
chrisneu68olds's Avatar
I have been looking at some documentation and have run into the term "Propeller Shaft" a few times. This term is usually linked to the option G71 - Propeller Shaft and is associated to the manual transmissions. Question: What is a "Propeller Shaft?" Is this just a fancy name for something?
chrisneu68olds is offline
Old March 20th, 2012, 11:53 AM
Tedd Thompson's Avatar
Not sure, but isn't it the drive line tunnel?
Tedd Thompson is offline
Old March 20th, 2012, 11:56 AM
Lord knows. Since people at this time liked to place interesting titles to common parts or functions, it could mean anything.
One that always got me is that when you look at the automatic gear selector, P,R,N,D,S,L, "S" doesn't mean "second", it means "super."
Old March 20th, 2012, 12:11 PM
starfire's Avatar
Propeller shaft is just a fancy name for the drive shaft.
And "L" means "Low". Some vehicles use "2" and "1" for Super and Low.
starfire is offline
Old March 20th, 2012, 12:13 PM
That is correct! We older farts (not old) remember this term well!
oldcutlass is online now
Old March 20th, 2012, 01:31 PM
I have no reason to doubt that and I suspected as much. By default all cars have a "propeller shaft" but I guess that you have to make it sound special.
On the 67 442 it was an "mandatory" part of the package (again I reiterate that all cars have a "mandatory" drive shaft if you actually want to go somewhere ) which leads one to believe that perhaps the "G71 Propeller Shaft" implies that there might have something special about it. Lighter? Heavy Duty? Or just a fancy name for Drive Shaft?
Old March 20th, 2012, 02:09 PM
DeltaPace77's Avatar
To smplify things, it propells the car. Have several older repair manuals, and all use that term. Took me awhile to figure that one out too.
DeltaPace77 is offline
Old March 20th, 2012, 03:31 PM
TK-65's Avatar
I do know the early 442s have a bigger prop shaft, part of the 442 option package.
TK-65 is offline
Old March 20th, 2012, 05:24 PM
citcapp's Avatar
Haven't heard that term in a while have to bring it up at a club meeting as a question to the younger generation and see what answers I get
citcapp is offline
Old March 20th, 2012, 05:46 PM
Maybe that is where the "G71" comes in as a 442 separate line item. I can assume that it would be perhaps larger in diameter or maybe the U-Joints are a little more heavy duty or something. Makes sense.
Old March 20th, 2012, 05:47 PM
ah64pilot's Avatar
Hell, even in Army aviation we use the term "Drive Shaft" to indicate the shaft that turns the propeller...figure that one out lol!
ah64pilot is offline
Old March 20th, 2012, 05:55 PM
Jetstar 88's Avatar
Yup, "Propeller Shaft" is just 1960's technical writing for driveshaft.
Of course, some Cubans with disdain towards Castro have made the term make more sense.
Jetstar 88 is offline
Old March 21st, 2012, 03:23 AM
Yellowstatue's Avatar
Prop shaft; PN 7804895 '65 - '67 w/ 4sp HD w/ 400 engine...sup 5697021.
Yellowstatue is offline
Old March 21st, 2012, 05:27 AM
Trying to remember member
wmachine's Avatar
Originally, the auto shafts were 2-pc with a rubber damper to absorb minor drive train vibrations and give a smoother ride. But with the stick cars, "they don't need no stinkin' dampers" and used a solid one pc shaft.
However, by '72 they were using the same dampered shafts as OEM replacements.
wmachine is offline
Old March 21st, 2012, 06:15 AM
And as those 2-pc sleeved shafts got older, the rubber would deteriorate, and that smooth ride went away!
Old March 21st, 2012, 06:27 AM
Actually, if the rubber deteriorated, forward motion went away, making for a VERY smooth ride!
joe_padavano is offline
Old March 21st, 2012, 10:01 AM
LOL!! Thats what happened after the rattling noise went away. Very smooth ride on the back of a flat bed.
Old March 21st, 2012, 12:40 PM
'87 Delta 88 Royale
rustyroger's Avatar
Propeller shaft (normally shortened to prop shaft) is the usual term for a rwd drive shaft this side of the pond, fwd shafts are called drive shafts.
It connects the gearbox to the back axle rather than the transmission to the rear end.
Roger.
rustyroger is offline
JackJack56Olds
Drivetrain/Differentials
June 14th, 2014 11:28 AM
Frogge467
March 24th, 2012 11:09 PM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
64 CUTLASS KEN
November 22nd, 2010 05:17 PM
Quick Reply: Question: "Propeller Shaft"
