explain reverse valve body with all forward gears
Old September 16th, 2010, 04:35 AM
chris83's Avatar
Was wondering if someone can explain how a reverse valve body works and how you shift it and if it would be good to keep for a street strip car
chris83 is offline
Old September 16th, 2010, 07:42 AM
The whole point of a reverse valve body is to make the shift pattern P-N-R-1-2-3. That way, when you are upshifting during a race, you don't accidentally shift from 2 all the way to R, which tends to get exciting at speed.
So long as you don't mind the difference, there's no reason not to use it on the street.
joe_padavano is offline
Old September 16th, 2010, 01:01 PM
chris83's Avatar
sweet thanks joe your awsome
chris83 is offline
Old September 16th, 2010, 02:03 PM
BlackGold's Avatar
"....no reason not to use it on the street."
Just make sure that the reverse valve body still shifts automatically, unless you like manually shifting at every stoplight and corner.
BlackGold is offline
Old September 16th, 2010, 02:21 PM
You say that like it's a bad thing.
Old September 16th, 2010, 03:18 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
It's handy for bracket racing as well.
My old shifter used to skip 3rd and go into neutral if I hit it too hard, and I went out a few rounds early because of it. Thank god for rev limiters.
J-(Chicago) is offline
Old September 16th, 2010, 06:07 PM
chris83's Avatar
thats the plan bracket race on week ends and still hit the car shows when im not driving the 74
chris83 is offline
Old September 16th, 2010, 06:10 PM
chris83's Avatar
hey j you got any parts i can use on the 81 for racing
chris83 is offline
Old September 16th, 2010, 06:26 PM
compedgemarine's Avatar
I had a '80 Z28 Camaro with a manual reverse valve body trans. it was fun to drive but spend some time getting used to the pattern. after that they are fun if you dont mind shifting it.
compedgemarine is offline
ukoldsrocket88
July 15th, 2015 02:09 PM
Kilmster
October 17th, 2014 05:19 AM
442NDTSS
February 17th, 2013 06:51 PM
louie
March 29th, 2012 03:34 PM
toymaker199
July 14th, 2009 07:51 PM
Quick Reply: explain reverse valve body with all forward gears
