Correct tire size
Thanks. The past owner had P235 70415, P215 70 R14 and P235 70R15. I don't know if he has 15' and maybe a 14" rim on this car. I guess the rim will be stamped with the rim size? And if he has 15" on it would it throw off my speedometer not having the right size rim? As you can tell I don't know what I'm doing and relying any help I can get.
those are different size rims, you can keep the 14 in rims on the front and put the 15s on the back. Tire size is personal preference for most (within reason, the tires have to fit the rim) A nice size 15 tire for the rear is 255/55/15 or 255/45/15. The fronts can be taller like 235/70/15 or on the 14 inch rims 225/70/14
costpenn
February 14th, 2020 04:06 AM
1972 Hurst Olds
December 19th, 2012 08:21 PM
ROCKET VAPOR
June 4th, 2010 09:47 AM
