66-67 Dash Removal pictorial
Old February 16th, 2018, 06:15 AM
lemoldsnut's Avatar
I had to removed a dash from a 67 Olds yesterday. This car was an F85 but the procedure is the same on Cutlass, 442 and Vista cruiser. This is a low option car with only heater no AC. Needless to say the more options the more stuff there is to work around.
I'm not sure how to post a link to here maybe one of the moderators can do that. If you go to my facebook page "Olds Parts and More" you can see it. Hope it helps those pulling a dash. I am not the best mechanic but have pulled a few of these so hopefully my experience doing these will help someone.
Constructive comments or questions are welcome.
Larry
lemoldsnut is offline
Old February 16th, 2018, 12:56 PM
Olds Fever
CRUZN 66's Avatar
This might help....
https://www.facebook.com/search/str/...stories-public
CRUZN 66 is offline
Old February 16th, 2018, 01:35 PM
Great write up... I copied all of your pictures from Facebook to here, as some people do not use it:
I pulled a dash on a 67 Olds today. I took many pictures and tried to do so as to help others that have had a hard time getting these out. This is not really that hard. Except for one nut. The one above the wiper switch. It is a hard one to get to. This one was removed from a car that has 71,000 miles. Yet it is 50 years old. The insulation on the inside of the firewall was in very bad shape and was all over the place so had to deal with that. I am not putting this back together so I removed the glove box door and liner to help with access. You do not need to do this to get the dash out. I also removed the radio you will need to do this. I took the heater control cables off at the heater box. If I am changing out a dash then I take the three screws off that hold the heater controls to the dash instrument panel (IP) I unplug the electrical wires at the heater controls and the lighter. I removed the tumbler from the ignition and left the ignition switch in the car. It is very hard to unplug. This car had some added on speaker wire that was zip tied to the dash wires so had to remove that. The nuts that hold the dash to the metal frame of the dash are 3/8 and I use mostly a flex head 1/4 drive ratchet and a deep socket to get them off. There is two on the right side, one upper and one lower at the end of the IP. There is also a few more along the upper and lower parts of the IP. On the left side there is two, one above the wiper switch, (this is the worst one to get to) and one below the headlight switch. You also need to unscrew the speedometer cable and with great care undo the circular plug in at the printed circuit. This take your time with and often it will break off a pin or two. The more time and care you take the better the odds of reducing this from happening. This is hard for those of us with neck issues and hand issues. So, take your time and do not be in a hurry. After you get it loose and wiggle it way from the firewall there is a screw that is vertical holding the wiring harness to the top of the speedo cluster area. Another way to do this is to removed the entire wiring harness with the fuse box. This is done by removing the screws on the inside at the fuse box and on the outside at the bulkhead connecting for the wiring harnesses.
To start the removal of the dash I removed the front seat and laid shipping blankets on the floor to make it more accessible and move comfortable to work on.
Glove box prior to removing the door and liner.
Glove box opening with door and liner removed.
speaker wires zip tied to the factory harness. These are not factory and were removed. You may find many things altered on your car. These are 50 year old cars. If they could only tell us their story.
Radio plug in, unplug this and the antenna wire prior to removing the radio.
lower mounting screw on the back of the radio
oldcutlass is offline
Old February 16th, 2018, 01:48 PM
Continued:
5/8 socket to removed the nuts on the radio **** shafts.
Radio loose
Most of the screws on the dash are either 3/8 or 1/4 inch sockets. I used a flex head ratchet and a variety of extensions.
ash tray mounting bracket, this does not need to be removed but helps with more clearance and access. again I am not putting this car back together so helps to removed all I can for access.<br/>
Here you can see the 3/8 nut lower center in the picture. This is what he mounting nuts look like. I believe there is 7 of them
looking towards the heater controls from the glove box area you can see another mounting nut in the lower right area
removing the heater control cables at the heater box. a 1//4 inch screw and a slide on locking washer need be removed. I find just take pliers and squeeze the washer. This makes it come right off and in if reinstalling you will need no washers.
Old February 16th, 2018, 02:08 PM
Continued:
and example of a not factory speaker that needed to be removed. These are 50 plus year old cars and will have things at times owners have added
This is the area by the ebrake light.
headlight switch
Here you can see the mounting nut below the headlight switch
You can see how the insulation is in poor condition and gets in the way, You can also see the not factory speaker wire and the round circuit board plug in on the back of the dash
back of the heater controls
This is the screw you can access after you get the dash loose from the firewall.<br/><br/><br/>
removing the screw holding the wiring harness<br/>
Here you can see the speedometer cable and past it the round circuit board plug in
straighten out a large paper clip to insert into the ignition tumbler to remove it
with the key in the tumbler insert the paper clip into this same hole then turn the switch to just past accessory, then pull the tumbler out.
Once this is done the ring can be removed holding the ignitions switch assembly to the dash
Old February 16th, 2018, 02:16 PM
Continued:
Here with the dash assembly out you can see the lower mounting stud to the right just below the headlight switch and to the left the mounting screw for the dash IP to the dash pad
The mounting stud between the speedometer and the heater controls.
the mounting stud below the center area of the dash
The mounting stud on the upper section above the radio
Mounting stud above the lighter area
mounting stud above the wiper switch. This is the hardest one to get to when in the car
grounding strap not correctly connected at the heater controls
Old February 16th, 2018, 03:28 PM
lemoldsnut's Avatar
Thanks I just hope it helps others.
Larry
Old February 16th, 2018, 03:53 PM
It will probably help me soon. I want to take mine out and clean it up.
Old February 19th, 2018, 05:59 PM
1967Supreeeme's Avatar
Thank you very much Larry!
1967Supreeeme is offline
Old February 21st, 2018, 06:44 AM
rroth01's Avatar
Location: Orion Township Michigan 30 Miles North of the Murder City
I have a Spread Sheet if anyone needs it.Nice job Larry
rroth01 is offline
Old February 21st, 2018, 07:22 AM
therobski's Avatar
yep been there done that. The small mounting dash fasteners were a challenge indeed. When I reinstalled the finished product-dash, I used star-nuts with external tooth lock-washers. I did not want to take a chance of one of them coming loose and get a "dash rattle or squeak". I installed all of the other new wiring needed for all the new accessories, used "ties" to make the job clean and accessible in case of service needed. For a novice I think it turned out pretty good. Is your old fuse panel any good?
therobski is online now
Old March 9th, 2018, 11:34 AM
golden rocket
golden rocket's Avatar
The Cutlass looks very similar to my 67 Delmont. Was having fits, trying to get ignition tumbler out last fall. Now that weather is starting to warm up, will give it another shot.
Will be following the pictures as I need to get the dash pad off to get it re-done, due to all the splits and cracks in it. This will help in getting what instrument panel lights are not working back in operation, also.
mike
golden rocket is offline
Old June 19th, 2019, 11:24 AM
steverw's Avatar
Great write up Larry.
My under dash insulation was so bad, i didnt want to breath it as it flew through the air.
I got my shop vac and vacuumed most of it out before i got started.
Steve
steverw is offline
Old June 28th, 2019, 07:25 AM
lemoldsnut's Avatar
Yes Steve that is a great idea as well. Many I have done need that to happen first as well.
I am now offering restoration of these dash instrument panels for 66-67 Olds cars. This is premium show quality restoration of your dash panel or exchange or outright purchase of a restored dash panel.
I can provide many pictures of these I have completed. These are vacuumed on aluminum as done originally and complete repainting of the argent/silver and black as original. I offer a 7-8 week turn around to get these done unless I have one in stock that is not already sold then can be done right away.
Contact me direct
Larry Moyer
Olds Parts and More
Redmond, Oregon
lemoldsnut@aol.com
541-815-4363
Old December 17th, 2019, 07:16 AM
lemoldsnut's Avatar
Had someone ask me about this in the past few days so thought I would comment so it goes back to the top
I am restoring these panels to show quality now.
as of this post have a 67 done that could use a new home.
sell them exchange with a good core or outright.
Larry
lemoldsnut@aol.com
you can see this at the top of my "Olds Parts and More" Facebook page as well
541-815-4363
Old July 18th, 2020, 09:35 AM
bobfo1's Avatar
Larry: Have there been any writeups like yours on how to Install a 66 67 cutlass dash?
bobfo1 is offline
Old November 25th, 2020, 11:01 AM
In Memory of Dad
540 Olds's Avatar
Just a promotion for Ron Roth dash restoration; I have a dash he did for my '67 442, and one of his dashes in another '67 I bought. BOTH are VERY NICE.!! You'll be happy with Ron's work as his passion for these cars shows in the finished product.
Bob 940-902-1266
540 Olds is offline
Old November 27th, 2020, 08:19 AM
lemoldsnut's Avatar
He is the reason I got into doing them.
The industry needed better service than he provides.
Old December 31st, 2020, 08:08 PM
Ttnc's Avatar
Great write up. Im sure going to use it soon.
Ttnc is offline
Old January 3rd, 2021, 10:29 AM
jackedolds's Avatar
Great write up - thank you. Any insight into where I can get this filler piece for a 66? Mine was missing when I got the car.
jackedolds is offline
Old February 13th, 2021, 06:06 PM
rroth01's Avatar
You are the reason I got Back in..You Sir are a Mess
rroth01 is offline
Old February 8th, 2022, 06:10 PM
Marc B's Avatar
Thanks for the writeup and pics. Getting this outta the way is my project for tomorrow.
Marc B is offline
Old June 10th, 2023, 06:58 PM
442hurstolds's Avatar
Continued:
Question, how do you remove the wipers and lights wiring and do you have to remove the cable to the left of the speedometer cable? And if so how? Do you pull it out or do you have to turn it a certain way?
442hurstolds is offline
Old June 12th, 2023, 07:01 AM
lemoldsnut's Avatar
It sounds like you are confused. The speedocable has to be unscrewed. There is a retaining nut clearly seen in this picture you commented on. The electrical connections at the wiper switch and the headlights both just up plug. The only electrical connection that is a little tricky to get unplugged is the ignition switch. It has 3 retaining clips to hold it in. This is why I recommend taking the tumbler out and retaining ring off the front of the dash to removed it from the dash instrument panel. This makes it very easy to access it once the dash is removed.
Hope this helps.
Larry
Old June 12th, 2023, 07:36 AM
Rocketguy's Avatar
The easiest way to remove (or install) one of these instrument panels is to disconnect the heater cables at the heat box, remove the radio, unscrew the fuse box, disconnect the peripherals like the courtesy lamps and steering column, and pull the whole I/P as a unit with the wiring harness and all the switches intact.
Everything else is much easier to work on when it's on the bench.
Wear a dust mask! And keep a fan going. That cowl insulation will give you a nasty sinus infection.
Rocketguy is offline
Old June 12th, 2023, 07:48 AM
lemoldsnut's Avatar
That is actually pretty close to the opposite of how they were installed. The only thing I would change is make sure the speedo cable is disconnected, and the dimmer switch and brakelight switch and grounds are disconnected.
Old June 12th, 2023, 06:23 PM
Hope this helps.
Larry
Okay, thanks for the help on answering my question. I’m just a little confused as I’ve never done something like this before.
Old June 12th, 2023, 06:46 PM
Andy's Avatar
Read this sticky and look at pictures, maybe print out and get under your dash so you can use the pics as a reference..I used this sticky to remove my dash, do yourself a huge favor and make sure you remove front seats..much more room to work with. Once you get under dash with a good light and use the references to identify all the parts you will see its really not that difficult..as stated, wear a mask and goggles to keep insulation dust out of your eyes and nose..if you have a good wet vac, vacuum up real good-before you start and also up under the dash vacuum good.. you can PM me and I will give u my phone number if you need to talk with me..Larry who wrote the sticky did a great job of showing how to remove this..
Andy is online now
Old June 13th, 2023, 04:49 AM
I already pulled the seats out because I am rebuilding them and that is a task of itself.
Old June 13th, 2023, 07:46 AM
Past Administrator
Oldsguy's Avatar
Enjoyed this thread. Looking at the pictures when the dash was still in the car made my arms itch and nose sneeze, been there, done that, don't want to again...
Realizing how the grounds were made for every electrical item by metal tabs, straps, etc. makes you appreciate after fifty years or more clean connections upon reassembly are really crucial and how intermttents can crop up before resoration with loose connectors.
Oldsguy is offline
radioburningchrome
July 19th, 2020 08:13 AM
70convert
July 25th, 2016 04:52 PM
Hotrodjimmy
October 30th, 2010 12:26 PM
The_Jeremiah
December 20th, 2007 11:31 AM
dholmes898
July 9th, 2007 09:13 PM
Quick Reply: 66-67 Dash Removal pictorial
