1970 Olds 442 Brake parts identification
Old July 12th, 2014, 01:03 PM
jimlabo's Avatar
Hi folks:
Need some help. I'm rebuilding the front end of my 1970 Olds 442 and pulled the front rotors and calipers. The car only has 60,000 miles and I'm wondering if the parts I pulled are original. Here are the caliper part numbers:
R 6463637 cast 179? CFD Delco Moraine
L 5463636 cast 228? CFD Delco Moraine
Also, the rotor has a circular grove and the pads have a raised ridge that fits in the rotor grove. Is this original/correct?
Thanks,
Jim
jimlabo is offline
Old July 12th, 2014, 03:15 PM
oldspackrat's Avatar
Not sure about the calipers but the rotors most likely are original. Those grooves are wear grooves, when the rest of the surface of the rotor is even with the grooves, it's time for new rotors. At least that's what I've always heard. Any pads used on those rotors will develop those ridges.
oldspackrat is offline
Old July 13th, 2014, 05:10 AM
Sammy70 455 Supreme
sammy's Avatar
I have been told that the single groove in the middle of the disc is an indication that it is original. Both my 71 w30 and 70 Cutlass have it.. Remember this is what I have heard, no proof
sammy is offline
Old July 13th, 2014, 05:20 AM
jensenracing77's Avatar
it all sounds like original parts and correct. The 179 and 278 on the calipers are date codes. The groove is on original brake rotors. I chucked a set of aftermarket rotors on a lathe and cut these grooves just to make them look original.
jensenracing77 is offline
Old July 13th, 2014, 05:27 AM
Sammy70 455 Supreme
sammy's Avatar
Amazing....something I heard in my shop is actually true
sammy is offline
Old July 14th, 2014, 11:08 AM
Lance
ROCKET VAPOR's Avatar
Originally Posted by jimlabo
Hi folks:
Thanks,
Jim
Same casting number that is on my original disk brake calipers.
ROCKET VAPOR is offline
scharpp
January 27th, 2015 09:45 AM
fennjones
February 2nd, 2013 11:31 AM
projectheaven
March 2nd, 2012 10:09 PM
jensenracing77
January 2nd, 2010 03:30 PM
Cameo White
April 7th, 2009 07:09 PM
Quick Reply: 1970 Olds 442 Brake parts identification
