Voltage regulator buzzin
Old September 1st, 2014, 05:03 PM
Chris J's Avatar
I installed an MSD HEI Pro Billet plug and play distributor on my 68 442 BB 400. When I put the car in gear the GEN light comes on and I can hear the voltage regulator buzzing, as soon as I give it some gas buzzing stops and light goes out. I have the original alternator that has been rebuilt and a new stock voltage regulator I have the idle set at about 950 to 100 that seems to be where the cam likes it. Do I need to run a different alternator or voltage regulator or both
Chris J is offline
Old September 1st, 2014, 05:39 PM
Sounds like a bad voltage regulator and the contacts are chattering..
oldcutlass is offline
Old September 2nd, 2014, 09:44 AM
stellar's Avatar
Make sure the reg has a good ground
stellar is offline
Old September 14th, 2014, 12:37 PM
Chris J's Avatar
OK replaced the voltage regulator with an A/C Delco D663, ground checked out good and battery tests good but light still on dimly and voltage regulator still buzzing at idle when car is warm. Do I need an alternator with higher output and if so what output should I go to? I have found some on line that can putout up to 120 with out modifying or changing the stock wiring harness.
Chris J is offline
Old September 14th, 2014, 04:07 PM
How much voltage is the battery seeing when the car is at idle? And with the rpm's up a bit?
delta_88_germany
February 22nd, 2014 01:48 PM
oldman72
September 24th, 2008 08:05 PM
ow30442
September 2nd, 2008 02:51 PM
rocket69
August 14th, 2008 09:09 AM
and1stp
September 17th, 2006 07:31 PM
Quick Reply: Voltage regulator buzzin
