nutral safty switch
Old Aug 19, 2008 | 07:37 PM
hamm36's Avatar
nutral safty switch
Another wiring question, I know...?
What will happen if the neutral safety switch is not used?
One side goes to the Ignition Switch, and the other to the starter. The starter wire is not being used, i have a remote (kill) switch that comes off the pink wire. Does anyone for see any problems with that?
Thanks, Carl - Dallas
Now that I think about it, anyway. I have seen several motor wiring harness with the purple cut when an HEI distributor is installed? Obviously this could be a problem in these cars as well? Mine is entirely removed when I rewired the fuse box.
Old Aug 20, 2008 | 04:53 AM
Oldsguy's Avatar
Past Administrator
Other than inadvertantly starting it in gear, no.
CroixDad
Mar 25, 2013 11:14 AM
mikemickunas
Sep 12, 2012 07:15 PM
Delta88Vert
Aug 12, 2012 11:39 AM
dan1s
Sep 11, 2009 02:49 PM
