95 Cutlass Supreme Conv. turn signal problem
Old Apr 20, 2007 | 10:05 AM
luther's Avatar
Hello. THis is my first Olds and first posting on this webpage, any help is appreciated. I just bought the car and noticed that the turn signal is not working all the time. The headlights/taillights work, brake lights brighten when pedal pressed, headlight brights work when turn signal arm pulled. I noticed that when I test the hazzard lights is when the turn signal stopped working for both lf. and rt. turns. Additionally, this car's cruise control has not worked since I bought the car >1 month ago. I got out the book to find the fuses to check, but I don't think this is the problem since the turn signals have stopped and started working again (only to stop once I tried to test the hazzards). Does this sound like a turn switch that needs to be replaced? If so where is it located? THanks! Ryan
Old Apr 27, 2007 | 07:23 PM
marcar1993's Avatar
That may, or may not be a turn signal switch, I'm not sure. But I'm 99% sure that the switch is located in the column, connected to the turn signal arm. It is that way on my mother's 1993 chevy.
Old Apr 28, 2007 | 05:40 AM
ozoneblue's Avatar
If you had brake pedal pushed while hazards are on the brake will cancel them. Keep them from flashing
Old Sep 29, 2007 | 10:41 PM
pinky's Avatar
I am wondering how you fixed that ?
I am curious as to get more details on the turn signal switch location and repair
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
rkk69olds
Jun 21, 2014 04:11 PM
jk121
May 14, 2007 01:49 PM
js_specials
Aug 18, 2006 10:31 AM
