ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical, Interior, and Other > Electrical
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old June 27th, 2009, 05:31 PM   #1 (permalink)
roy341
neutral safety switch
67 cutlass, 330 cui....
last year i removed the 2 speed jetfire and replaced with a 200r4. problem is that the neutral safety switch nolonger is functional because of the extra gears.
does someone make a switch that will work. i have a console shift?
also, i've run into probems with the switch not working correctly. in other words, i would turn the ignition and the car would not start. if you look at the amp gauge, you will see the car pulling amps w/o ignition kicking in. i thought it was the neutral switch not working but i have connected the two wires that run to the switch so that should not be a problem.
additionally, the problem only occurs spuradially and not everytime.
the battery is brand new and all lights work great when engine is not running. could this problem be the ignition switch???????
roy341 is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old June 27th, 2009, 07:30 PM   #2 (permalink)
Oldsguy
Hot Rodder at heart Administrator
Oldsguy's Avatar
Yes it surely could, or your starter, or the wiring to in the ignition/starter circuit. A thorough inspection may turn up a faulty connector or wire. Can't answer the question about the neutral safety switch application but I would think the one for the shifter should be the one you want to use. Are you using an aftermarket shifter or what?
__________________
Dan
'77 Cutlass Supreme
'46 2 door
"The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB.
Oldsguy is offline   Reply With Quote
Old June 27th, 2009, 08:26 PM   #3 (permalink)
svnt442
Knowing what shifter you have will be the first step to solving this issue.
Most aftermarket shifters are provisioned for both neutral safety and backup light switches.
I had a B&M Quicksilver shifter years ago. It came with two switches and all the hardware to install them. Very easy hookup.
__________________
Randy
1970 442
svnt442 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
71' Auto (floor) Neutral Safety Switch 72' Convertible Interior/Upholstery 6 May 21st, 2009 01:46 PM
Neutral Safety Switch -67 floor shift Flye Transmission 1 March 30th, 2009 04:45 PM
Neutral safety switch location? OhMyOlds Aurora 3 October 21st, 2007 01:44 AM
Neutral safety switch? footbrake Electrical 1 June 12th, 2006 07:10 PM
Neutral safety switch oldsnut7098 Electrical 1 August 10th, 2003 11:06 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
