OEM AM/FM Radio Install !?
Old Jun 19, 2009 | 04:25 PM
ent72olds's Avatar
Registered Luser
Exclamation OEM AM/FM Radio Install !?
Hey guys,
I bought an am/fm radio('65), off e-bay for my '65 Vista to replace the mint working am! Installing was no prob, switched 12V no problem...ant no problem...thought I had the dash speaker right, but no sound? Radio turns on, lights up, and I hear the music coming out of the radio itself, but barely audible! Can't get it to come out of the speaker! The speaker does work!) Can't see that I'm hooking this up wrong....it's pretty simple! Does this sound like something could be wrong with the output of the radio? Guy said he tested it, but you know how that goes! Thanks.....
Old Jun 19, 2009 | 05:17 PM
svnt442's Avatar
I don't know a whole lot about these older models, but I'm gonna take a guess and say it's a tube radio. You could have a bad final tube. You never know.
Old Jun 19, 2009 | 06:02 PM
Nilsson's Avatar
Let us know what you find out as my 69 Cougar has the exact same symptoms and I have always assumed it to be the speaker.
Old Jun 19, 2009 | 06:57 PM
ent72olds's Avatar
Registered Luser
Thanks, no it's a transistor...
Old Jun 19, 2009 | 07:00 PM
ent72olds's Avatar
Registered Luser
I put the original radio back in in the meantime, and everything works fine...
Old Jun 19, 2009 | 07:24 PM
oldsonharmont's Avatar
Assuming it has 12 volt negative ground wiring... does the impedance of the radio match the speaker? (8 ohm, 4 ohm etc...) Is the antenna connected correctly? If the speaker is grounded to the dash then there should only be one wire leading to the speaker. Listen for any audible pop or hum when you power the system, at least you'll know the speaker works.
Old Jun 19, 2009 | 09:26 PM
ent72olds's Avatar
Registered Luser
yes on the ground wiring, I assume the radio and speaker impedance match. It is the original speaker, has never been removed, works perfectly with original am radio, speaker is grounded to the dash. Only one wire for speaker to radio. When turned on, radio lights up, and I can hear the music very faintly, not from the speaker but from the radio itself. When I unplug the speaker wire from the radio, there is no change, but when I touch the speaker wire to the body of the radio, the speaker pops and comes alive, but still no music.....
Old Jun 20, 2009 | 02:49 AM
Yellowstatue's Avatar
Smile Hush mode
Sounds like the audio transformer is out to lunch...need technical repair; if there is a model number for the radio, let's have it...Cutlass did not have AM/FM untill '67...fullsize was '63
Old Jun 22, 2009 | 03:23 PM
ent72olds's Avatar
Registered Luser
You're probably right on the transformer...I can't see anything I might have done wrong?! The model # is Delco 7289698...thanks.
Old Jun 23, 2009 | 03:00 AM
Unhappy I.D.
Your 7289 number is in the '65 era but the 698 does not show up some people selling radios on E-bay refer to a website ID'ing the numbers for the radios they are selling...I am using a Delco radio service manual with a six page radio index in the front..
Old Jun 23, 2009 | 05:18 AM
ent72olds's Avatar
Registered Luser
Thanks, I'll check again, maybe I read it wrong?.....
Old Jul 3, 2009 | 01:35 PM
Flye's Avatar
If you went from an AM to an AM/FM, Does it have a rear/front balancer or anything that you could turn the **** to fade the radio to the front speaker?
Just a thought....
Old Jul 10, 2009 | 08:53 PM
ent72olds's Avatar
Registered Luser
Just a thought....
Thanks, for trying...
317Cutty
Nov 26, 2013 10:28 PM
DeltaDevil88
Jul 4, 2013 09:59 PM
DeltaDevil88
Apr 17, 2012 02:17 PM
twagor
Jan 13, 2011 08:06 PM
Creativeindy
Aug 24, 2009 06:50 AM
