salvage yard electric fans
Old Apr 26, 2009 | 05:09 PM
oldjunk's Avatar
HI Guys!
I am getting ready to put a stock 455 in my 1972 Olds Cutlass S. I have a new 4 row aluminum radiator. I would like to convert to an electric fan and I was wondering if anyone has had success with salvage yard fans, and if so, what make and model of donor car works best to donate the fan. Any thoughts?
Thanks for your time.
Old Apr 26, 2009 | 05:32 PM
MN71W30's Avatar
With a 4 row aluminum radiator it should cool very nicely. I have used the 2 row aluminum radiators with 1 inch tubes and they work better that any old 4 core core radiator I ever had. I standard clutch fan will do the job just fine.
I don't know the HP differences between elec and standard fans, and I question if it is worth the trouble but I'll watch and see what other guys say.
Dave
Old Apr 26, 2009 | 05:41 PM
bigoldscruiser's Avatar
2 '66 98's
I saw a nice conversion on a Cutlass at the Oldsmar show and he used a fan setup from a Dodge Intrepid. He said it was very inexpensive and fit perfectly.
Old Apr 26, 2009 | 09:46 PM
ThyPlumber's Avatar
Re 455
Becarefull there, Is your car originally a 455 car? if not you will need some new springs up front, the electric fans are a good idea, but rember if you alterntor is stock it is only 65 to 71 amps? I would install the factory fan and cluch set up, it works well, If you want extra cooling put the fans on the grill side of the radiator and use an electric thermostat set 20 or thirty degrees higher than the temp the thermostat in your manifold is set at. Extra saftey/cooling for extreem heeting conditions, but wont run the electrics mos of the time.
Old Apr 26, 2009 | 09:50 PM
ThyPlumber's Avatar
Why 455?
Why a 455? the 350 has an over square design and will make as much power as the 455, and the 350's parts are cheaper, and way easier to install goodies like headers on a 350.
Old Apr 27, 2009 | 12:05 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I used fans from a lumina mini van. For 10 bucks, you can't beat it.
Your water pump bearings will thank you as well.
Old Apr 27, 2009 | 06:46 AM
You're right. Big block Olds motors are worthless. As a public service, I'll gladly come buy and pick them up and I won't even charge for it...
Old Apr 27, 2009 | 08:03 AM
citcapp's Avatar
What he said
Old Apr 28, 2009 | 05:41 PM
19Starfire62's Avatar
Me next
Old Apr 30, 2009 | 09:29 AM
Oldsguy's Avatar
Past Administrator
read my sig line.....
Old Apr 30, 2009 | 01:36 PM
88 coupe's Avatar
Junior Member
Originally Posted by oldjunk
........ I have a new 4 row aluminum radiator. I would like to convert to an electric fan ........
The factory cooling system would be trouble free.
If you are a "hood up and lawnchair" type, disregard.
........ you will need some new springs up front ........
Not enough weight difference to even think about a spring change.
Why a 455? ........
Because he has one.
........ the 350 has an over square design and will make as much power as the 455, and the 350's parts are cheaper, and way easier to install goodies like headers on a 350.
Did you get your education from a Chev site?
Norm
Old May 1, 2009 | 03:10 AM
Yellowstatue's Avatar
Smile Comedy Central
KRICHEN922
Apr 19, 2010 12:33 PM
Natas
Apr 12, 2010 02:52 PM
tdubis
Feb 26, 2009 04:57 PM
49rebuild
Nov 24, 2008 09:44 AM
49rebuild
Sep 23, 2008 10:27 AM
