Missfire help
Old Mar 16, 2009 | 04:38 AM
2tuff65's Avatar
Unhappy Missfire help
1965 Oldsmobile delta 88, 425.
Just got done putting a new intake manifold and 4bbl carb, When i went to start the car It has a dead miss in it, Its been about 12 years since i adjusted the timing on a car and i have not been able to find a shop manual for this car
I checked the firing order, Checked the point gap, spark plug gap and the spark plug wires, They all seemed to be in decent order but i do have new wires on the way.
What would be the next step(s) i need to take and where could i find a manual for the olds 425/65 delta 88.
Thanks again for any help
Chuck
Old Mar 16, 2009 | 07:40 AM
Chuck
There are several 1965 Chassis Service Manuals on ebay right now.
Old Mar 16, 2009 | 12:15 PM
2tuff65's Avatar
dang it i forgot to check eBay and thought i covered all my bases before posting!
Thanks again Joe
Old Mar 17, 2009 | 02:09 AM
88 coupe's Avatar
Junior Member
Faxon Auto Literature.com.
Norm
Old Mar 25, 2009 | 09:25 AM
ricdiculus's Avatar
Did it run O.K. before the intake swap? Have you checked for leaks with starting fluid(carefull)? How about the points dwell angle (gap)? Is it a steady mis(same hole every time) or is it eratic?
Old Mar 25, 2009 | 09:33 AM
ricdiculus's Avatar
oh yeah. Timing wise I wold start with a 6-8 degree advance at recomended idle speed. this will get you in the ballpark. and i think you want 17-18 degrees of dwell if memory serves.
Old Apr 3, 2009 | 06:55 PM
2tuff65's Avatar
manual is ordered and on its way!
In the mean time when loking at the distrubtor cap how can i tell what one is the number one plug?
It says it should be marked with a "1" but the cap i got is blank
Old Apr 3, 2009 | 09:19 PM
blowitup's Avatar
#1 is 1 over to left of retainer.#1 cyl on v-8 olds is drivers side front cyl.
Old Apr 4, 2009 | 06:00 PM
2tuff65's Avatar
thanks again for all the help guys!
gonna try and fire her up tomorrow!!
chuck
nolabigdawg
Nov 16, 2014 06:45 PM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
martine
Jan 22, 2009 01:13 PM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
