Blower
What setting? The classic symptom of a failed blower motor resistor is that the blower works only on the highest speed setting. If that was your case, I would suggest replacing the blower motor resistor. However, now that the blower doesn't work at all, the resistor is perhaps not the answer. But if the one speed it was working at was the highest speed, you might change the resistor, anyway, and see what happens. If the highest speed was the only one working, the resistor likely needs to be replaced, anyway.
TECH9TWISTA
June 25th, 2007 12:05 PM
