Aux Fan Wiring Question
I'm installing dual aux fans in my 68 442 and have leads that are marked to go to the ignition switch. I have already used the spades on the fuse box for both battery and ignition with other items. I have installed a Vintage Air system, so the heater circuit is not being used. Is this circuit acceptable,or should I look elsewhere?
Jeff
Jeff
