Why don't 1157 LED bulbs work in 66 Toro?
Old February 17th, 2017, 04:07 PM
simrek1's Avatar
I just bought a bunch of 1157 LED bulbs to replace the incandescent 1157 bulbs in my '66 Toronado and none of them work. The two staggered pins and the two contacts line up and the socket length is exactly like the original bulbs. The 1156's work, but not the 1157's. I'm totally baffled at this point. I've replaced a lot of 1157s on various cars, but they don't work on this one. Has anyone got any suggestions?
Thanks,
Paul
simrek1 is offline
Old February 17th, 2017, 06:25 PM
Fred Kiehl's Avatar
You may have to install an electronic flasher. The LEDs do not create enough current to operate a standard flasher.
Another possibility is the polarity of the circuit. The LEDs will not operate if the voltage is reversed.
Fred Kiehl is offline
Old February 17th, 2017, 06:26 PM
Tedd Thompson's Avatar
Try swapping the the wires around before you do anything. LED's only work one way.... Tedd.
Tedd Thompson is offline
Old February 18th, 2017, 04:45 PM
You can't swap an 1157. The side pins are staggered and only fit one way in the socket (unless you are a gorilla). More to the point, the solder tabs on the bottom are both positive (one for parking/tail and one for brake/turn). The outer shell is always negative, as is the socket.
joe_padavano is offline
Old February 18th, 2017, 07:19 PM
I have seen some bulbs where the manufacturing process is less than stellar which allows the bulbs to be put in either way. The wrong way, the contacts don't line up. Another issue is that the spring loaded contacts are not reaching the bulb contacts.
oldcutlass is online now
Old February 18th, 2017, 08:14 PM
csouth's Avatar
This ^^^^ will probably need a flasher that has its own ground.
csouth is offline
Old February 19th, 2017, 07:16 AM
^^^This has been my experience also.
To the OP. Get a set of jumper wires and test the LED bulbs directly on the battery. Connect the outer shell to ground. Touch the hot wire to first one then the other of the solder terminals on the bottom. This way you know positively if the bulbs are good or not before chasing a problem that may or may not exist.
Old February 19th, 2017, 07:51 AM
simrek1's Avatar
I did check the bulbs in another car and they worked fine. I ordered some Wagner 1157 bulbs @ $5.00 ea. instead of $1.00 (probably Japanese manufactured) to see if the metric conversion or product quality is causing the problem. I'll post the results when I get them.
simrek1 is offline
Old February 19th, 2017, 08:12 AM
So the bulbs aren't the problem. Figure out what is.
Do the park/tail functions work? That is independent of the flasher.
Old February 19th, 2017, 08:31 AM
simrek1's Avatar
Everything works fine with the incandescent bulbs but I'm adding sequential turn signals and they work better with LED bulbs. I think that the older sockets were less forgiving than the ones made in this century. That's why I'm trying the US manufactured SAE dimensional and possibly higher quality Wagner bulb. I'll post the results after I try them.
simrek1 is offline
Old February 19th, 2017, 08:36 AM
BZZBRand
BZZBRand's Avatar
Probably need a load resister to make your LED 1157's work. Check at a good auto parts store that has experienced counter personnel to show you the options, etc.
BZZBRand is offline
Old February 19th, 2017, 08:56 AM
simrek1's Avatar
I'm thinking that it's a connection issue.
simrek1 is offline
Old February 19th, 2017, 09:29 AM
Just a thought, even though the brake/turn signal function will probably require a different signal stat, if your directional selector stalk is not in the center position then the lamp won't work.
Old February 19th, 2017, 07:35 PM
csouth's Avatar
If you are planning on adding sequential LED's go ahead and get the LED flashers because you will need them. I have them and needed 2.
csouth is offline
Old February 20th, 2017, 07:12 AM
simrek1's Avatar
"If you are planning on adding sequential LED's go ahead and get the LED flashers because you will need them. I have them and needed 2."
CSOUTH:Thanks for the input about the LED flasher unit. Why did you need 2 of them?
As far as the bulbs go, I should have added that I can't even get the running / parking light filament to light up. I even tried pushing the wires further into the sockets to make the connection. I hope that the better bulbs do the trick, I've never run into this before and I've changed over a bunch of other vehicles to LED.
simrek1 is offline
Old February 20th, 2017, 07:27 AM
csouth's Avatar
Digi-Tails recommends 2, but say that you only NEED 2 if you have LED's for taillights and front lights. I found that my hazards or blinkers would work depending on which socket had the LED flasher installed. I installed a second LED flasher and it solved my problem. Keep in mind my car has totally new electrical rewire with American Auto Wire harness.
csouth is offline
Old February 22nd, 2017, 10:57 AM
simrek1's Avatar
Sure enough, the Sylvania 1157 bulbs (not Wagner as I said earlier) worked just fine in both the front and rear. It has to be a dimensional / fitment issue, not electrical and it probably has something to do with the older design of these 1966 sockets. Everything is also working just fine with the standard flasher.
simrek1 is offline
Sid
October 1st, 2015 04:53 AM
kitfoxdave
October 13th, 2014 02:17 AM
Hairy Olds
August 29th, 2014 09:22 PM
ELECMAN
March 5th, 2012 08:21 AM
Aceshigh
March 9th, 2010 06:32 PM
Quick Reply: Why don't 1157 LED bulbs work in 66 Toro?
