starter wiring clarification please?
Old June 11th, 2011, 12:08 AM
Delta88royal's Avatar
Hi guys, trying to button up some last details on my engine rebuild. Running a 1974 Olds Delta 88 Royale, with a 455.
I've read many threads trying to confirm what I've done but I still want to double check!
I have 4 cables total, running to my starter-
1, Battery cable to largest stud on starter solenoid
2, Ignition coil 'yellow' wire to 'R' on starter solenoid
3, Neutral start switch 'purple' wire to 'S' on starter solenoid
4, 'Red' wire, from the horn relay i think, to the same large stud as the battery cable on starter solenoid. Is this correct?
Also, what is the stud on the actual starter motor housing? Ground?
One more thing, my braided ground wire from my block to the firewall, is that connected to a stud on the firewall?
Many thanks, this site has helped me tons!
Mike
Delta88royal is offline
Old June 11th, 2011, 05:38 AM
TripDeuces's Avatar
The stud on the back of the starter case is for a bracket that supported the rear of the starter. Not all cars came with it but that's it's purpose. I'm finicky about ground wires because grounds are the biggest cause of electrical issues. I would ground your car several ways. Engine to body, engine to frame, frame to body. That way your bases are covered.
TripDeuces is offline
Old June 11th, 2011, 10:53 AM
Ok, thanks, good to know what that stud on the starter housing is for. And I'll be sure to add a couple additional ground wires.
So the fourth 'red' wire does go to the same stud as the battery cable?
Daniel Marsh
Drivetrain/Differentials
March 19th, 2014 05:37 AM
delta881972
May 16th, 2013 08:02 AM
defiant1
May 3rd, 2011 08:52 PM
MDchanic
January 30th, 2011 09:00 PM
dre
January 3rd, 2011 08:05 PM
Quick Reply: starter wiring clarification please?
