Spark plug gap
Old Jun 18, 2015 | 09:10 AM
patmills's Avatar
442forsure
Spark plug gap
I have a 425 Toronado in my '66 442. I believe the engine has a W30 cam in it. My car is a 4 speed.
I am putting a Pertronix Ignitor in the stock distributor and am also installing a Pertronix Flame Thrower 1.5 ohm coil.
I am going to use Delco R43S spark plugs.
Could someone tell me what gap I should use in the plugs?
Pat
Old Jun 18, 2015 | 09:59 AM
There's no set guideline here, and I do not know whether your coil has a significantly greater output voltage than the stock coil does, but I would say that the stock 0.035" is probably your best bet.
If that coil has a significantly higher output than original (disregarding hype), you might go up to 0.045".
Old Jun 18, 2015 | 11:50 AM
You may have to experiment a little. I have an HEI on my '69 400-G and have found that 0.045 works pretty well. I don't know how hot the spark you'll get from your Pertronix combo will be, so at a guess I'll suggest starting with 0.040. A mitigating factor may be those AC R43S plugs which are pretty cold and could be expected to foul with a stock ignition.
Old Jun 18, 2015 | 04:49 PM
patmills's Avatar
442forsure
Thanks for your advice.
Pat
Old Jun 18, 2015 | 06:51 PM
cdrod's Avatar
Rodney
How can you tell if the plug gap is too large?
Old Jun 18, 2015 | 07:40 PM
Car runs bad.
Old Jun 18, 2015 | 07:49 PM
Smoke comes out of the coil...
bonesbmx
Jun 2, 2020 02:10 PM
ChrisM
Mar 7, 2009 08:07 PM
boese1978
Mar 16, 2008 03:50 PM
ChrisM
Nov 1, 2007 02:23 PM
66starfire
Jan 3, 2007 10:31 AM
