Neutral safety switch?
I have an 85 Cutlass and am trying to wire the neutral safety switch from my B & M shifter to it. Does anyone know which wires coming out of the column I have to tie into. I already did the back-up lights, but am having a real problem finding the neutral safety switch wires. Any help is greatly appreciated.Thanks-Russ
if you have a digital multi-meter, in your ohms setting there is a setting thats called continuity, just unplug your wires put your positive on one end and take your negative to probe your other wires, you may have to use a jump wire to reach the other end. the first wire to make a beeping sound is the wire you are looking for.
miss442
miss442
oldspackrat
November 17th, 2014 06:31 AM
