Low Beam Headlights Cut Off
Old November 5th, 2010, 09:05 PM
cutlass47's Avatar
For several years the headlights on my '72 Cutlass have not been working properly. When I turn on my low beam headlights and then try to turn on the brights by hitting the dimmer switch, the low beam headlights go out on both sides and the high beam lights do not come on at all. Just the parking lights are on. Should I just replace the dimmer switch to see if that solves the problem? Also, how do I check the headlight bulbs to make sure they have not burned out?
cutlass47 is offline
Old November 6th, 2010, 04:05 AM
All four high beams burned out at once? Not likely.
Check the connections from your high beam switch. If you can make them light by connecting the feed to the high beam line, then your problem is the switch.
MDchanic is offline
Old November 6th, 2010, 06:32 AM
STOP call'n it a Chevelle
arodenhiser's Avatar
I think it is dimmer switch. It a a quick cheap reapair. Two screws and about $12 at Napa.
Adam
arodenhiser is offline
Old November 6th, 2010, 07:42 AM
Lady72nRob71's Avatar
It is remotely possible also to have a short in the high beam circuit that causes the headlight circuit breaker to open when the high beams are on.
Is there a delay from when you switch from highs back to lows?
If not, the dimmer switch should be the issue.
Lady72nRob71 is offline
Old November 6th, 2010, 07:56 AM
Wise guy.
MDchanic is offline
Old November 6th, 2010, 07:39 PM
Originally Posted by mdchanic
wise guy.
- eric
:d
junior supercar
June 15th, 2013 08:59 PM
Flye
April 29th, 2013 07:23 PM
woody30
Tech Editor's Desk
September 15th, 2012 08:45 AM
scott71
June 18th, 2011 07:04 PM
BaileyJD1
May 1st, 2008 11:45 AM
Quick Reply: Low Beam Headlights Cut Off
